Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Local / Regional / National > USA > South Central States
South Central States Arkansas, Kansas, Louisiana, Missouri, Oklahoma, and Texas.
Old 08-16-2004, 01:19 AM   #1
Johny5
Johny5's Avatar
Johny5 is close to perfectionJohny5 is close to perfectionJohny5 is close to perfectionJohny5 is close to perfectionJohny5 is close to perfectionJohny5 is close to perfectionJohny5 is close to perfectionJohny5 is close to perfectionJohny5 is close to perfectionJohny5 is close to perfectionJohny5 is close to perfection
Send a message via AIM to Johny5
texas drift event august 21st. be there or be octagon...
same place as last one, mineral wells airport. drifting is $50 and spectating is $5.
http://www.texasdrift.com/ for more info and coverage of previous texas drift events.
Directions to Mineral Wells Airpark
Directions: Take I-30 or I-20 West, You will see an exit 80/180 that angles to the right towards Weatherford. You will then see a split in the road 80 to Weatherford and 180 to Mineral Wells, stay on 180. This will take you through Weatherford, once passed Weatherford you will go approx. 18 mls to Mineral Wells. Once you get into Mineral Wells, go to the 2nd stop light and take a left (this is 1195 or farm to market road) follow the road down for 2 miles. You will come to a 4 way stop (Mineral Wells Airpark), take a left and follow it down until you see a fork in the road, go to the left, it will lead you to the track . Call 817-243-2286 for questions.
the track layout we use at this location is very badass with much longer turns than before. the concrete is a little rough so be prepared with a backup arsonal of tires. there is onsite tire changing and you can change your tires for $7 a wheel (they do work with stretched tires).
www.stewartleask.com
Johny5 is offline   Reply With Quote
