![]() Join Date: Sep 2012
Sr20det starting issues
S13 blacktop starts up revs to 2k and then dies. Thought it was the maf but I've tested two n62 mafs and they both do the same thing. If I unplug it it will stay running but if you plug it in while it's running it kills it. I have a enthalapy tuned ecu for it as well. Hope it's not the ecu. Any ideas?
Update..found out maf isn't getting any power. Checked the continuity between the ecu and maf and wiring seemed good but no power at the quick connect to the maf. Was pulling voltage from ecu for signal wire but doesn't reach the connection
