Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Forced Induction
Old 03-24-2013, 02:22 PM   #1
Enjuku Racing
Enjuku Racing - Precision 5128 Turbo Chargers
Precision PT4828 Turbocharger - Nissan SR20DET - Nissan SR20DET
PTE's Direct Replacement Performance Upgrade Turbochargers feature the following:
• Exclusive CEA® (Competition Engineered Aerodynamics) compressor wheel machined from a 2618-aluminum forging
• Liquid-cooled, dual ceramic ball-bearing center housing rotating assembly (CHRA)
• Higher efficiency and faster transient response for maximum power and performance
• 51mm inducer compressor wheel
• Compressor cover options:
- "B" compressor cover 2.8" inlet/2.0" outlet
- "E" compressor cover 3.0" inlet/2.0" outlet
• 53.8mm, 76 trim turbine wheel
• Turbine housing options:
- T25 .64, .86 A/R wastegated
- T3 .48 A/R with 5 bolt discharge (with wastegate hole)
• Wastegate actuator included with "B" compressor cover and T25 housing
These are Amazing Turbo chargers!! Rated to 450+ HP Easily!!!
http://www.enjukuracing.com
[email protected]
Old 03-24-2013, 03:52 PM   #2
sideways_s14
sideways_s14 is an unknown quantity at this point
Send a message via AIM to sideways_s14
nice, wish there was an exhaust housing available a bit bigger for an rb25
sideways_s14 is offline   Reply With Quote
Old 03-24-2013, 05:48 PM   #3
edpogi
edpogi is an unknown quantity at this point
Turbo
Shipped to Las Vegas, nv 89146
edpogi is offline   Reply With Quote
Old 03-25-2013, 08:24 AM   #4
Gar9854
Gar9854 is an unknown quantity at this point
Any idea on how these compare to the 64 or 86 AR GR2871r's
Gar9854 is offline   Reply With Quote
Old 03-25-2013, 08:31 AM   #5
smink
smink's Avatar
smink is an unknown quantity at this point
Shipped to wv 26431?
smink is offline   Reply With Quote
Old 03-25-2013, 09:23 AM   #6
Enjuku Racing
Your 2871R and 5128 utilize very similar sized turbine and compressor wheels, but the 5128 utilizes a smaller diameter center shaft portion on the CEA compressor wheel (due to the material and design it can use less material and still be as rigid) allowing the overall length/surface area of each individual blade to be larger. The larger surface area allows the turbo to generate a bit more power than a comparably sized 2871R.
[email protected]
Old 03-25-2013, 07:02 PM   #7
white-s13coupe
white-s13coupe is an unknown quantity at this point
KA $$$o0
price shipped to 11596...
also i bought an isis ka cold pipe
and i want to buy the m-spec intercooler kit...
can you leave out the cold pipe and include the greddy bov flage instead for the same price ???
white-s13coupe is offline   Reply With Quote
Old 03-26-2013, 11:54 AM   #8
Enjuku Racing
PM's sent!
Also for the intercooler piping question, call the shop (352)241-8399 and speak with one of the sales reps and they should be able to get that taken care of for you.
[email protected]
Old 03-26-2013, 12:02 PM   #9
Enjuku Racing
They are offered in a T3 turbine housing with .48 A/R.
[email protected]
Old 03-26-2013, 11:37 PM   #10
slickdrifter
slickdrifter is an unknown quantity at this point
price shipped to 97080 with t3 housing..
slickdrifter is offline   Reply With Quote
Old 03-27-2013, 06:55 AM   #11
evan_aggie
evan_aggie is an unknown quantity at this point
2 questions.
1) It appears that this compressor housing has holes drilled on the underside such that it can be re-clocked 180 degrees. Application: 300zx TT. Can you confirm if this can be used on a vg30dett?
2) How much for (2) shipped to 78613.
Thanks,
E
evan_aggie is offline   Reply With Quote
Old 03-29-2013, 03:35 PM   #12
Enjuku Racing
PM's sent!
[email protected]
