Help me with my english paper FAST PLEASE!
My teacher just sprung an assignment on us, and we have an hour and a half to write 2 seperate paragraphs about this book.... problem is, I didnt read the book because, as anyone who HAS read it will agree... it is CRAP!!!
it is "Rosencrantz and Guildenstern are dead" by tom stoppard. its a stupid exestentialist waste of ink, and I refused to read it. anyways, the questions are: Who is the stronger character, R or G? be sure to define what you feel makes one character stronger than the other Since the play contains elements of both the comic and tragic traditions, what appears to be Stoppards view on man and the nature of man? be sure to support your conclusions with crap and stuff. if you have read this play or know a site that can help me, PLEASE DO!!! btw, I just watched the movie, which is supposedly very accurate, and I still am screwed with writing this. |
![]() Join Date: May 2002
rent the movie again
tim roth and gary oldman iirc two awesome actors. book is good. read it. otherwise google for help on it. im sure there are a many sites about it. Last edited by Dousan_PG; 05-23-2003 at 08:57 AM.. |
someone tell me what you think:
Topic 1: Arguments could be made either way depending on a persons beliefs, but I believe that Ros is a stronger person, due to the fact that he is able to accept what is reality for them. Throughout the entire play, Guil continuously seeks out a reason why everything is happening, and he seems to voice every thought that comes into his head on the topic. Ros, on the other hand, takes the "sleeper" approach, and seems seem dumb, while he is actually smart. This is immediately evident when the play begins, as Guil attempts to find reason in the behavior of the coin, voicing his thoughts, and seemingly being the "intelligent" one of the pair. Meanwhile Ros simply collects coins, because he has already figured out on his own, that the coin is going to be heads every time. Later in the story, at the beginning of the second act, Ros and Guil debate over the discussion they just had with Hamlet, and the scoring of it: Ros: He murdered us. Guil: He might have had the edge. Ros: Twenty-Seven--Three, and you think he might have had the edge?! He murdered us. (II, p. 56-57) It becomes evident again that Guil is desperate to find reason and comfort, while Ros is able to accept reality and move on. It may seem to go against reason, but when you are in a desperate situation, it takes much more strength to embrace reality, than it does to try and reason it out. |
#6 | |
I hope when you get home you are more playful :-p |
#8 | |
Inactive Admin
![]() Join Date: Mar 2002
![]() #/f/showthread.php?s=&postid=255757 Ok, fo sho, it ISN'T 'homework' but it's still work that you're supposed to do on your own so your teacher can get a beter idea of how well you're learning. Thanks for the clarification, Aaron. |
