![]() Join Date: May 2012
I?m having trouble hitting boost on my black top Sr. I?m also running really rich and cuts off around 3500 4K rpms (tryna hit boost)
Here?s a list of what I have on the motor. Wiring specialties harness *Rs Enthalpy Rom Tune P2mcoilpacks 720cc injectors CircuitSports fuel rail Isr fuel pressure regulator Cusco catch Can AEM guages oil psi/ A-F Ratio/ turbo Tomei exhaust mani Tomei Turbo outlet Z32 maf T28 S14 turbo 255 walboro fuel pump A little history about the motor: I bought the swap off of my buddies buddy about 2 years ago, everything was working fine when he had it running ,no issues at all, so. I had the swap sitting for about a year then I put it into my chassis and I?m having trouble hitting boost like I said.. the motor starts up everything is good , I just can?t hit boost cuts off like I said .. I swapped out the maf to another z32 one and still the same thing , I?ll try and clean them both tmrw.. any pointers ? Ty |
