Recommendation on a OBX Helical Limited Slip
Hi I'm looking in to buying a new rear end for my car. I'm trying to figure out are the obx ones any good. I know there was one guy that did a write up on it but I check it a day ago and it hasn't changed. So would you all recomend the S15 or the OBX Helical Limited Slip. I auto cross alot and the new did is not holding up to the SR out of the corners. SO what do you all think
![]() Join Date: Nov 2004
If you searched you would've found these.
OBX Helical LSD for S13 OBX Helical Installed in S14. Ongoing Review. If only you searched...
I was deciding on the obx and s15. I chose the s15 becuase alot more people have it on their cars with no complains. Not saying anything bad about the obx because I have heard a lot of good reviews about them also. I would just pay more now knowing that it works.
Sale: Hello Kitty Horn Button S14 Rear Valences K.Y. Gordon the Thief (Tony Chen) |
Autox Technician
![]() Join Date: Dec 2001
2 ways are too unsettling for autocross/ track use, IMO.
I've heard enough good things about the ATS carbon diff that I'll probably end up with one. I still might try out the OBX since they're cheap enough to be disposable.
![]() Join Date: Jul 2003
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 2 reviews
it may feel this way, but to really get the good times around the autocross course, full grip is the way to go. torsion driven LSDs is what i recomend for autox. Anyways, thsi is going off topic.
I've never tried OBX but it sounds like its hit or miss just like many "knock off" companies. Im sure most units will work fine but there have been a couple cases with Hondas that once u force those axles, in, they wont come out. It sounds like a tolerance in the manufacturing issue.
HouseBuyers365.com Quote:
#6 | |
Autox Technician
It's too bad nobody makes a torsen for the 240 (as far as I know). Probably more of a PITA to retrofit a torsen diff in as well.
I think a helical lsd is the same as a torsen one. According to sportcompact article http://www.sportcompactcarweb.com/pr...silvia_part_3/. I know that Quaife make a Torsen one but it 1300. A little to much for me.
#9 | |
Autox Technician
![]() Join Date: Nov 2005
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 22 reviews
well i have a obx for sale if you want. i'll sell it cheap too b/c im getting a 2way. let me know if your interested. i used it like once lol...it worked great though i did a simple test to do a launch and saw 2 nice black lines.
#12 | ||
Autox Technician
![]() Join Date: Aug 2003
what about a gear-type Mechanical Diff? I was under the impression that those were the same as Torsens
Petition Nissan to Make the IDx on http://IDxClub.co ! |
