How Do I Get My Cluster To Work!?
So i bought a 1990 Nissan 240sx with an sr swapped by the PO. The wiring is pretty messy and my whole cluster doesnt work.
I want my whole cluster to work..ive searched and seached And All i see is that the the rpm gauge isn't going to work because i have an Sr. is this what i need?http://www.ebay.com/itm/JDM-NISSAN-2...1657ee&vxp=mtr Thanks! -Trent
Just a 16 year old kid trying to slide. |
![]() Join Date: Jun 2003
Trader Rating: (129)
If your car was originally single cam you will need a dual cam tachometer for the tach to work. Otherwise there is no reason every single other thing on your cluster should not work. Nothing else needs to be modified when doing an sr20 swap, at least not on the cluster end.
My guess is that when the previous owner did the swap he didn't bother wiring up the dash connector. It is a plug that comes from the ecu and feeds the cluster info. FRSport has an excellent write up on how to do an SR swap wiring. I would start there. |
ITS LISA'S FAULT!!!
Trader Rating: (41)
make damn sure none of the wires in the clusters subharness are split in any way, ESPECIALLY the ground wire!!! these are 20+ year old wires that have been cooked in the sun under the dash. they will split and break very easily! took me hours to one day to figure out my ground wire snapped in my sub harness when i swapped my digital cluster to an analogue one in my last coupe. NOTHING worked! as soon as i found the wire and fixed the split, everything worked perfectly!
Thanks a lot guys! Its nice to not get trolled and have someone tell me to search.
Really appreciate it! Sent from my XT881 using Tapatalk
because you made it evident that you actually HAD searched. You knowing that you need a different tachometer is proof of this.
all goddam day we see people who claim they searched, but in reality if they had, within the first 3-5 links they would have found the answer. i give you credit for doing a bit of research FIRST before asking the question/starting a thread. you'll find that most people on here are more than willing to help, we just get tired of answering the same basic things over and over and over again |
Whats the difference 240boi? And I know how that is. I juust recently got into 240s, I have always been into 4x4s, all day long thats what I see over on pirate. Thanks again guys
