350z 18" on S13
1993 Nissan 240SX Hatch
KA24DE, 5spd KYB Struts I recently did the 5 lug and z32 brake swap on my s13. S14 FLCAs/spindles/hubs Z32 Front and rear calipers/rotors Z32 Rear hubs I also acquired a set of wheels from a buddies totaled '05 350z. Theyre the 18" touring wheels. When the install was complete, i noticed i had some alignment issues. The front wheels were extremely toed out and the camber was a bit out of whack. I took it to a local shop to get aligned and this is what it looks like now: FL Camber -2.5 Caster 5.7 Toe .04 FR Camber -2.5 Caster 5.1 Toe .04 RL Camber -.8 Toe .15 RR Camber -1 Toe .16 With that said, i know ill need aftermarket support to get the numbers within my personal specs. I've encountered another problem though. When i turn the wheel completely left or right, the bottom spring seat on the strut turns and hits (closes the gap between the tire/strut) the top edge of my tire. Does anyone have any experience with this problem? I can take pics if need be. -RK |
![]() Join Date: Jun 2003
Trader Rating: (129)
if i'm understanding what you're saying, then you could probably get away with adding a 5mm slip on spacer and that would resolve the issue.
