S14 revival build
starting this thread so i have a way of logging my entire build and to also be able to share everything i did so here goes!
i picked up the car about 2 weeks ago in canton Ohio for 800$ came with 4 tires 2 with 3/32nds of tread and the other 2 with about 6/32nds of tread and a 5 speed tranny out of an s13 (no spot for cas yet :/) its a 1995 s14 says its an se on the title but i have yet to confirm that fully. and yes it is automatic for the time being as i have more important issues to take care of first before a manual swap.
when i first saw the car i could tell it was in need of being saved by a new owner. it came on cut springs with blown shocks, bald tires, leaking air, barely started, stupid stickers all over the place, bad paint job you get the idea. for 800$ i felt it was worth it cause there's only 3 spots of serious rusting the rest of the under body is clean. the engine bay was also decent not much done to it and a clean interior
