smoke after new cat and o2 installed
91 w/ 98 ka24de (<--supposedly) w/ all s13 stuff (using s13 maf and stuff). auto to 5spd. only mod to engine is walbro 255 pump.
so dealing with this smog thing i have, i went ahead and installed a new o2 sensor (universal one that i crimped to the stock end--bosch instructions), drove around for a minute then came back home. then went and installed the cat. well after i installed the cat, i noticed it was smoking during idle (didnt do this after the o2 install or before). it was fully warmed up (because i drove it back from the muffler place). it was cold, but not cold enough to see your breathe. not sure if this is normal or anything, but it hasnt done this before, so im just really paranoid now (dont want to keep dumping money left and right). ill post up tomorrow with what color the smoke is and how it smells. |
![]() Join Date: Jan 2005
its probably condensation as the cat converts hydrocarbons to water, get an adjustable fuel pressure regulator to go with that 255lph, it makes you run too rich
![]() Join Date: Jun 2003
Trader Rating: (129)
most likely its just residue on the cat. often times new exhaust components will smoke for a while after install (usually a few hours or so). if its still smoking after a few days then i'd be concerned.
![]() Join Date: Dec 2002
Every CAT I've ever installed, smoked for a bit after install. It's just the converter breaking in, kinda like new brake pads. Remember the CAT gets really hot. Prolly burning off any stickers or packaging crap that got stuck in the openings during shipment. My old CATCO had stickers on it that just burned off after install, little smoke...no biggie.
Plus since you install a walbro, you're running even more rich then a stock FPR, so you're getting alot more fumes coming out the exhaust. Be sure it's not exhaust fumes coming out of a leak due to the install. Fresh gaskets? new mounting bolts?, CAT mounted in correct flow direction?
Don't mess with my monkey...he's loaded. |
ok smoke kinda dies down. but smells like rotten eggs. but yeah how much richer am i running? maybe this is the case why im failing smog at idle (running too rich = high HC??)
*quoted from autorepair.about.com*
So judging from your comments, you prolly have a bad FPR due to installing the Walbro. Sometimes a slightly faulty FPR will go out when pushed, ie. the Walbro, I would go with a Nismo FPR and a fuel pressure gauge install to monitor.
change the fpr, a walbro raises the static fuel pressure by .5 bar wchich is alot more than the ecu can compensate for, nismo adjustable and a gauge will fix it
[quote=eerrrrr;1785729]ok smoke kinda dies down. but smells like rotten eggs. quote]
Lol. Last time I got a new cat it smelled like fresh pretzels. But yeah my car smoked a little while idling until the cat broke in. |
