Sr20det throttle body for s13
Hey guys just wondering what you guys recommended for an sr20det throttle body upgrade. I want alittle more throttle response and would it increase alot of hp? Just wondering. Im pushing 400whp atm. Thanks!
Redtop? Blacktop?
For reference here are the specs on the different TB for SR's. S13 SR20DET throttle bore = 60mm S14 SR20DET throttle bore = 50mm S15 SR20DET throttle bore = 50mm
1990 S13/SR20 |
Tomei sells a 70mm throttle body. If this isn't big enough you can use a Q45 with the right adapter. I believe they are between 80-90mm.
1990 S13/SR20 |
Are you putting down 400whp, or just assuming you're making this much? If so, I would imagine you'd seem some improvement but nothing mind blowing. IIRC the stock SR20 60mm TB is good for about 350-400hp.
Without listing what you've done with the motor, I don't think anyone can really give you a good idea wether or not it's worth upgrading the TB.
1990 S13/SR20 |
![]() Join Date: Jul 2005
Waste of money
We can make 500-700 horsepower maybe even more on the OEM throttle body. Using a larger part there just makes the car more difficult to drive and reduces the resolution at the pedal, reduces fuel economy, etc... its all negative, there is very little positive benefit at 500 horsepower and less for sure. |
#11 | |
#12 | |
![]() Join Date: Aug 2008
#13 | |
With the aspect of forced induction you can only do so much. pretty simple all you can do is smooth things out porting/polishing cause you are forcing air in. CFM in duration will play a big part but to an extent there is always a capacity or limit to where it become less efficient IE to small of an IC or displacement. |
| 240sx, s13, sr20det, throttle body |
