![]() Join Date: Jun 2002
Lightweight doors?
is there a such thing as a lightweight door(s)?
I have never seen it, wanted to know. Nothing carbon cause i still want to live but definetely something lighter than stock cause its heavy like a bee - atch. dan
"...But my tires were wet!" |
Admin Asshole
![]() Join Date: Mar 2002
Sure just remove everything from the door that would normally protect you in an accident. That'll make it lighter.
"Speak softly,..." -Pres. Teddy Roosevelt "Be polite, be professional, ..." -Gen. James Mattis |
![]() Join Date: Sep 2003
remove everything except for the inner pipe in the door.. cut the inner part off... basically left with a door skin.. make sure u use some protection foam on the edges...
S14 TrackSlut coming to a raceway near you... 510 TimeAttack on its way... |
#4 | |
OWNED NEWB!
-"HELL...LUMBERG FUVKED HER" |
![]() Join Date: Jun 2004
I foreget the exact website, but do some searching the website ends in .jo they have carbon fiber doors for the S14 and S13.
I've even seen door inserts they replace the entire inner panels with a carbon fiber piece.
#8 | |
![]() Join Date: Apr 2003
well i mean if you have a properly built full roll cage (obviously not optimal for the street)
you dont even need doors so THEN a carbonfiber shell replacement would work out.
Team Pterodactyl SHARK ATTACK!!! LookOutDrift Quote:
![]() Join Date: Jan 2004
OH HECK YEAH THEY DO!! and I want them baddddddd. HPI manufacturers a carbon fiber door that "weighs 15.4 lbs with out glass or accessories when your stock door can weight up to 40lbs with out glass or accessories. This provides you with a weight saving of up to 25lbs per door. The HPI carbon fiber doors are also exact copies of the stock door so all stock components such as glass and door handles are functional and fix correctly."
http://www.lsauto.com/hpidoors.asp
I'm from Florida so I'm probably a bit more strange than you |
![]() Join Date: May 2004
I you have a full cage then get a cf door, but if you have a cageless car that you drive daily, then don't even worry about it. Anything you could do to save a meaningful amount of weight, will make you very dead in a side impact crash.
![]() Join Date: Dec 2002
Rasty Japan makes an FRP door. Cheap too.
i tried to google rasty japan... nothing or at least i found nothing
happen to know there address i like to see them? yeah i dont wanna die, just want too lose weight of the car some more but still have the door re-enforced somehow. like something made out of lighter material.
![]() Join Date: Apr 2005
you just have to deal with it. besides I have never heard of anyone complaining that the doors were oh so heavy. maybe you are too weak or lazy. just take off your door panels and remove the plastic layer and other BS. if your doors are manual then take off all the other bs and just have the door lock and lever. if your power your screwed so hush and deal with it. you want to reduce weight. take out ish from other parts of the car.
feel the rythym. feel the ride. get on up. it's bobsled time. COOL RUNNINGS!!! formerly sideviewcivic Save a Horse. Drift This Cowboy. AirBag Club Member #0014 |
#14 | |
And everything has been said to help you out there, protection foam... or I would say it again. when you get side swiped ![]() |
#17 | |
not only that, but he's only got three more posts than the original poster, who joined 2 years earlier as well. |
![]() Join Date: Dec 2003
I wonder how much those seibon doors cost.
I was planing on going with a pair of manual doors after my pass side door ate mountin but if a pair of CF doors is fair priced I would pick em up instead. Those HPI doors are nice but way out of my price range.
