i have bad frame rot i was wondering if i could get any suggestions with how to fix.
Thanksframe repair.jpg Click on image to enlarge |
AFC #1
![]() Join Date: Oct 2003
There are replacement inner rails.
Looks like the other side has had this done already and this side has had some square tube stock welded in.
![]() Join Date: Oct 2006
rotisserie but i cant imagine that going very well.
why not get it on a lift and do it from under or how about just put it on ramps and get under there. id just buy the liners as mentioned above because they are cheap enough or just find a cleaner shell.
92 Coupe ka-t |
AFC #1
You can ether grind down the spot welds or drill them out. Then grind out the rest of the rusted mess.
xcessive manufacturing makes replacement rails... heres the link
Xcessive Manufacturing id suggest completely removing the part of your rail thats rotten weld this in place and then id clean the rest of the surrounding area up and i would then undercoat the hell out of it.. im not sure if they are spot welded in but if so there is a certain drill bit you need to use..... im sure you can get it at a fastenal or somewhere you can buy body repair stuff maybe even harbor freight... |
