S13 SR20DET total partout HKS Greddy T25
Located in Queens, NY
Shipping under buyer's expense + 3% pp fees PM or call/text (347) 676-0389 PayPal address is [email protected] Trades: Red Bride BRIX I or II, Ergo I or II, Red DMAX floormats, Defi BF Amber Gauges, ARC stuff Just began fully parting out my S13 SR. Everything's for sale, if you don't see it then PM me. I got all misc. bolts and nuts like tranny bolts, etc. PM me for pricing. S13 SR Blacktop Head Complete and Mint - $350 S13 Blacktop block w/ rod knock complete - $300 S13 SR 5 spd transmission no grinds, shifts perfect - $275 Turbo Lines - $25 T25/T28 Oil Drain Hose - $20 T25/T28 Turbo to Manifold gasket OEM - $10 CAS - $100 IACV (works fine) - $70 Powersteering Pump and Bracket - $115 Alternator and bracket w/ bolts - $100 Water Outlet - $25 Water Inlet - $20 Coil Packs x4 - $65 Coil Pack Harness - $30 Throttle body/ tps - $50 Stock Exhaust Manifold - $35 Stock Intake Manifold - $40 More will be updated tomorrow All these parts have only a couple hundred miles on them. Everything is in MINT condition. Wiring Specialties S13 SR into S13. only used for 1k miles pretty much NEW. Upper harness only. Lower harness is sold. $295 Type X SR20DET J4 stock ECU $100 HKS Turbo Actuator - $85 Nismo Thermostat - $75 S13 SR20DET Valve Cover Powdercoated Royal Purple (small dent barely noticeable, pic doesn't really show how deep the purple really is) - $100 Brand New Duralast Gold Miata Battery (Perfect for FMIC, $100 retail, no shipping) - $65 Gates S13 SR20DET Heater Hoses w/ Clamps (for those doing swaps, perfect fit) - $40 S13 Non ABS manual driveshaft - $75 Manual Trans Crossmember (mint cond, just caked on dirt) - $35 S13 Radio Brackets - $15 Stock Garrett T25 turbo - SOLD T25 Inlet Pipe w/ gasket - SOLD T25 Outlet Pipe w/ gasket - SOLD T25 Oil Drain Tube - SOLD T25/T28 Turbo to Elbow gasket OEM - SOLD Stock Turbo Elbow - SOLD Stock 370cc injectors - SOLD S13 Fat Blacktop O2 Sensor - SOLD Greddy Divided Turbo Outlet - SOLD Apexi Power Intake - SOLD Purple Samco Radiator Hoses - SOLD Nismo Motor and Tranny Mounts - SOLD SR20DET Purple Togue Factory Pulley Set - SOLD Z32 Fuel Filter and hose - SOLD Starter w/ bolts - SOLD Brand New S13 SR20DET Fan Shroud - SOLD SR20DET stock intake hose - SOLD SR20DET Ignitor Chip - SOLD Circuit Sports BMC Heatshield - SOLD Walbro 255 lph Fuel Pump - SOLD RS*R Downpipe - SOLD ECU Brackets - SOLD Radiator Stays - SOLD Circuit Sports SS Turbo Lines - SOLD S13 SR20DET MAF (52F00) - SOLD Tomei Rocker Arm Stoppers New in Box - SOLD Wiring Specialties S13 SR Lower Harness - SOLD Last edited by leung; 09-06-2012 at 09:41 PM.. |
