#34 | |
iPhone 4S compatibility
I'm thinking about buying a CDE-HD138BT from you. Do you have experience with the iPhone 4S? Will it work with this unit? Will it charge? Can I use Pandora with it? (I see they list Pandora control for Android & BlackBerry, but not iPhone). Will I be able to use the phone hands free? Is there any other feature that won't work? Thanks, Chuck |
#36 | |
![]() Join Date: Oct 2006
Trader Rating: (163)
Pandora BT control:
Full Pandora control via USB cable:
So it's weird that Alpine didn't integrate iPhone Pandora control into the CDE-HD138BT which is their flagship model. Alpine fully supports Apple, but for some reason they gave full Pandora control to the Android/Blackberry for their two highest end models. With all of that being said though, I don't find myself switching Pandora channels all of that often anyway... so I would be fine with the Pandora BT control. And the fact that you don't need to have the phone plugged in for Pandora if you are ok with the partial control. Of course you can still change the station or thumbs up/down from the iPhone. So you will be able to stream any audio from your phone via BT. |
#37 |
Well first off the W910 is long discontinued. Second of all the 920 is the replacement for the 910... which the 920 is a far better unit aside from the slightly smaller screen. The 928 is a completely different beast than all of them. It has an 8" screen to start off with. Which means it will not just drop into any double DIN spots. You would need to do some custom fabrication to get it to fit into anything that Alpine doesn't make an install kit for. The reason Alpine is producing the 928 is because a lot of new vehicles have OEM radios that are larger than double DIN's. So Alpine is making custom install kits for the more popular vehicles.
#40 | ||
As for measurements, let me see if I can come up with anything. There's not the normal specs out there since it's not available yet. |
#41 | |
![]() Join Date: Apr 2012
#42 | |
That sounds like it will be what I need. I haven't used Pandora that much, anyway. I'm replacing a TDA-7563, w/ a 12 disc changer. Will the 138 fit in the same sleeve? Is the body of it any deeper? I remember that I was barely able to stuff this unit in the dash when I installed it, so if this one is any deeper, I will be in trouble. What do you like for round speakers? I have 5" recessed holes factory cut in my doors. It's not really feasible to enlarge them much. It's a truck, with a gas tank behind the seat, so I don't have many options for other speakers. Kick panels have vents in them, so that's out. I could probably hang something under the dash. Suggestions? Chuck |
#43 | |
I officially can't find any measurements. Alpine tech support doesn't even have them yet. The exact measurements will not be known until close to the release date.
For speakers I will only use and recommend Hybrid Audio... as long as you are willing to spend $100+ on a pair of speakers. If you are looking for a $69 pair of speakers then they won't have anything that cheap... you would need to go to Alpine or something similar. What kind of truck is it? Putting speakers under the dash, firing down, is a really bad place. In the muscle cars for example I usually ditch the vents in the kick panels and put 6.5" speakers there: ![]() ![]() ![]() ![]() ![]() ![]() |
#44 | |
I don't have a problem spending 100.00 + for speakers, if that's what you recommend. The truck is a 1977 Ford F-250 regular cab, that is my daily driver. (I also have a 1950 Ford F-1 with the same head unit and changer that will also need this upgrade). Will a pair of these speakers in the doors be enough, or do I need more? Removing the vents is not an option, as the right side is directly connected to the heat/A/C unit. I lived with a pair of Alpine door speakers for years, so I guess a pair of really nice Hybrid Audio speakers should be substantially better? Chuck |
#45 | |
#46 | |
Another thought. What if I got the CDE-136BT, since it allows full iphone control, and just get the app for Sirius for the iphone? Chuck |
#47 | |
Imagine 6.5's $229 shipped ARC Audio XDi804 $239 shipped Please let me know if you have any other questions. Also, here is some good reading material on the Imagines: http://hybrid-audio.com/downloads/wh...Crossovers.pdf http://hybrid-audio.com/downloads/sp...ine_Manual.pdf |
#48 | |
What do you think about using the iphone to get Sirius, and the CDE-136BT head unit? The links you posted are dead. |
#49 | |
The links are taken from their site... not sure why they don't work. You can find them under Downloads. |
#52 |
Looking for a radio that has bluetooth and a remote . Price wise as cheap as possible because no one is going to see it . It also needs to have pre-amp outs (2 would be great) aux outs can be in the front not that big a deal . I also need a pair or 6.5 round speakers or a component set up .
#53 | |
As for the speakers, I HIGHLY recommend the Hybrid Audio Imagine series. They compete with other manufacturer's $500 sets of speakers. They come in the box as a coax, but come with all of the necessary mounting hardware/options to install them as a component. They run $239 shipped. |
#55 |
You might of missed it, but I just added the INE-S920HD to the for sale thread a couple days ago. And I added the CDE-W235BT about 3 weeks ago. The INE-Z928HD, which is the over sized unit, is set for July. The IVE-W535HD is July/August.
I am also an authorized JVC dealer now. I should be receiving product any day. They have some really nice double DIN units with some killer features. I will post those up once I get them in. |
#57 | |
I'm curious about those JVC units and your opinions on them when they're released.
#58 |
![]() Join Date: Sep 2008
PM sent...
You Americans and all of the added features you can utilize from these head units...We don't have any HD radio frequencies, and we don't have Pandora support ![]() |
| alpine, broadfield, cd player, head unit, ipod |
