![]() Join Date: Feb 2002
*NOW IN STOCK* Price: $306.00
![]() ![]() ___________________________________________ Tomei- Turbine Outlet Pipe, RB20, RB25 Efficient High Flow Design For Both RB20 & RB25 Engines With a smooth inner walls, high flow capacity, easy to install flange design for an easy direct bolt on application. Compatible with the stock turbo and the Tomei ARMS Turbo will contribute with improving the power output. Designed to suit a Φ76.3mm front pipe. The internal diameter has been enlarged by 120%. This will significantly drop exhaust back pressure Designed to be a hassle free installation. We have incorporated a dimple in the pipe where the bolt for the flange is located. To allow ease of access to both bolts and nuts to allow a quick, trouble free bolt on application. __________________________________________ Click here to order ===> http://www.enjukuracing.com/products...rb20-rb25.html
This elbow should not interfere at all with LHD steering shafts according to Tomei.
A Tomei ARMS M8265 bolt on turbo is shown in the picture above. Currently in prototype phase and is not yet available for purchase.
This elbow is designed to bolt up to a factory skyline with a factory skyline (or aftermarket skyline) down pipe. If you have a RB swapped 240 and you currently have a downpipe in place with a factory turbo outlet pipe, this will bolt up just fine. Otherwise, you will mostly likely have to utilize a custom down pipe or a RB/240 swap specific downpipe with this Tomei Outlet.
#9 | |
