hey guys I have a quick question...
I just finished overhauling my engine (all new gaskets since the old ones were leaking like mad). After reinstalling everything how it was (even where I had the distributor marked and installed properly) my engine seems to be misfiring pretty badly. What was weird was that I was playing with the distributor to see where it would run best, and I had to rotate it completely in the opposite direction from where it was before I pulled it out.... What did I do wrong??? Idle issue 240sx for Zilvia - YouTube ^ sound of whats going on |
yea i would check the firing order first and foremost and you might wanna check your wires, the old ones might be cooked and could possibly be conducting like shit. did you get new spark plugs?
1989 built/corn fed ka-t hatch 519whp
![]() Join Date: Sep 2012
Advice to the op, don't go replacing parts unless you know they are broken. Don't listen to people who tell you to change your spark plug wires for no reason.
Your timing is off by one tooth is my guess. If you messed with the chain, make sure it is in correctly. Also make sure the dizzy marks line up with each other.
Ka24 t3/t04b + Z32MAF + 550 subys + Walbro 255 + enthalpy Tune + 91 octane |
#6 | |
But as shift_down did suggest and i would have suggested next had it not been stated, check cam and dist timing
