#61 |
no driver's side window
passenger side mirrors are broken need new hubs tint is bubbling and peeling blow shocks cut brake lines automatic tranny blow motor cracked dash dirty engine bay and interior not registered
crap |
#62 |
Number one injector is forked, other then that its pretty sweet. Couple of dents and paint is cracking in places (car is black and a daily driver ......
Want a aftermarket front swaybar hopefully it will lessen the body roll and then I can stop wasting money on this shitter. |
#63 |
For some reason i don't think there is a 100% perfect condition 240sx. Even if someone was to claim that it was they probably haven't checked good enough.
Oh shit. To add to my list. No insurance ticket. Fictious plate ticket. Fudgedifuckfucks.
#64 |
doesn't start too well sometimes
a/c has a leak in the system its probably time to change the diff fluid headlights dont go down few enough things where i dont really give a shit to fix em |
#69 |
wastegate dump tube cracked, then fell off, burning hole in a/c line. and florida is hot.
leaky ps lines near reservoir (that grimy shit is everywhere) 19psi + 145k mile KA with old leaky valve seals = slow consumption of oil, slight blowby mysterious super small coolant loss, sucks up overflow tank too needs paintjob annoying rattles popping up everywhere from semi-solid motor mounts otherwise runs like a champ and keeps up with 11 second 500hp cobras
97 240sx ka-t. 12.8 @ 108mph. for sale $8K in Florida. 08 mazdaspeed 3. faster + quieter = sleeper. |
#70 |
exploded ka-t. what's new?
#72 |
*Guage and ac lights don't light up at all. using blue leds powered by cigarette lighter at night to see
*Brake light doesn't go off *Defroster doesn't work *Small crack on front windshield with a bigger one spreading it's way slowly but surely *On cold start need some footwork with gas pedal otherwise engine dies out *Check engine light likes to play peek-a-boo *Release bearing really shot to hell *Vents won't turn off *Torn Bellows Boot on Rack and Pinion but steering is beautiful still *Windshield and Hatch glass seals very bad likes to drink water when it rains *When front defroster is turned on engine idles VERY low *Massive oil leak going on down below and as a result motor mounts and virtually all bront end bushings bathed in lots of oil *Exhaust has something inside shielding rattles and kinda sounds like a BOV when i shift around 2500 rpm so not too bad *Major Cracked dash(i know me and thousands others) *Trip Meter can't reset to 000. Reading is messed up *Passenger Side Seat Belt starting to go out *Front Right Strut mount likes to "moan" a lot *Paint going bald on roof as well as hood and hatch *Rear wiper works when it wants to *Reverse lights don't go on *Tranny likes to fight to shift sometimes *Cruise control button lights up making you think it's working but accel decel does nothing *Horn likes to honk when i turn the steering wheel the slightest bit so pulled fuse *Steering wheel likes to make hissing noise when turned in either direction *Trunk hatch cable release loose so 80/20 i have to do it using key Holy shit i had no idea my car was that fucked up haha until i listed each of those things. I think that's it for now however giving all those shorts and cracks and leaks what not my car seems to have the damn thing drives good and is one of the cleanest ones i see in my area as far as body damage goes. virtually none all fenders straight and aligned clean title except for salvage engine. i love my nissan it keeps on going strong despite the fact it needs more attention than an 18 year old drama queen ![]() |
#73 |
-Missing floor mats (have to use my old honda civic ones for now
)-Clutch pedal makes a squeek noise everytime I step on it (Still havent gotten around to WD-40ing it )-Puffs out a little bit of white smoke after it sits idle for about 5-10 mins -Typical broken radio trim -Typical missing shift boot -Typical trunk rattle -Ugly ass OEM Style aftermarket spoiler on it that the previous owner installed -LED bar falling off gay fake OEM spoiler -Mysterious power steering leak somewhere -A/C needs recharge -Tons of worn bushings -Diff leaking oil around cover gasket -Valve cover gasket leaking -Steering wheel is soo worn it looks like a dog chewed on it -While taking off the tint, I fucked up the Defrost lines on the rear window -Alignment WAYY off -Exhaust leak where top part of header meets downpipe -No money to fix alignment -Damn base models dont have a rear sway bar But whatever, I still love my freakin car ![]() |
#77 |
![]() Join Date: Aug 2005
^+1(especially hot beverage, air vent cupholder will make it worse), i kind of wonder where else except my 2 hands and thighs lol
anyways heres mine... Urgent!!!! 1.Right signal lights corsswire with 1st headlight(1st click on combination switch) gonna take to shop 2morrow, i mean later 2day Kind of urgent 1.Clutch is on the edge of dying, slip when hot 2.Black box needed for Speedo reading (has been waiting for months and they still send the wrong item, thas what the shop said) Well...need to fixed and buy sooner or later 1.Replace Tie Rods (right side inner tie rod bent) 2.every single bushing (worn out) 3.Tension rods (Old enough to replace_ 4.Fix the knock back on BBK (maybe replace Master cylinder) 5.Tiny PS leak (pain in the ass) 6.Camber Arm (negative rear cmaber is good but its killing my tires) 7.Front Strut bar (i have rear but no front lol) 8.fuked up mud-guard If i have the money... 1.Subframe 2.New body kit 3.Paint job 4.New coilover (either flex, super drift, or hypermax) 5.Sway bar and last but not least: Clean the CAR!!!!! |
#78 | |
exactly, cant be broke if you aint got it.
I was going to, but I can not think of a sig less than 75 characters. |
#79 |
![]() Join Date: Oct 2001
![]() ![]() ![]() Feedback Score: 1 reviews
HICAS - needs new headlight
COUPE - Needs wiring to get the SR running CRX - Needs brakes / new hood cable Miata - Needs new fender / door GTZ - Needs wiring Corolla - Needs new bumper STAN - needs cash for above |
#80 |
-drivers side window rolls down but takes about 3 minutes to roll back up
-paint on roof faded -corner lights and drivers side fender held on by zipties because of previous accident when I hit a fukkin couch on the freeway -coolant leak on heater hose -no power steering belt or ac belt I'm in the process of fixing things little by little whenever I have time. other than that runs like a charm and pulls hard! |
#81 |
this thread is funny... but the fun part is fixing it all up... then sitting back and admiring what you accomplished...
anyways, here's my list 1. i look like an idiot at the gas station because i have to put down the rear seat and crawl in from the inside to pop the trunk or the gas cap 2. shift boot is literally disintegrating 3. leaking oil 4. dents on every corner 5. tan hatch on a juniper green car 5. steering wheel shakes vigorously at 55mph (needs alignment) 6. no headliner 7. passenger side seatbelt is stuck (sucks to be the passenger) 8. CEL (EGR problem, good thing i got my smog check before that happened) 9. reverse lights don't work (fuse keeps blowing out for some reason) well thats all i could think of... but i love it because i only got it for $500 and it runs! |
#82 |
nothing works on the pasanger side of the car window seat doesnt move mirror broken, other then that its a 240 so everything is broken now or will be soon.
#84 |
![]() Join Date: May 2004
My cars pretty screwed up...
1. Virtually all suspension peices worn out. 2. Clutch chatters after driving around the city for awhile. 3. Engines leaking real bad from everywhere. (crack on upper timing cover, leaky seals, crap) 4. Engine = 233k miles. 5. Engine bay super dirty. 6. Tranny doesnt wanna go into reverse sometimes unless i roll the car forward first. 7. CEL comes on every now and then either complaining about an EGR problem or an injector leak. (as far as i know, neither is true, but not sure) 8. Interior super dirty. 9. Poo brown interior. (with black dash though) 10. Could use some paint. 11. Leak from PS hose with the metal fitting in the middle. 12. Rear brakes arent working properly. Cant get them to lock with the E-brake. 13. Not very much brake pedal pressure. Pedal goes down when I pull up e-brake. 14. Plenty more, im sure... |
#85 |
-huge dent in gas tank that pushes the gas away from the pump
-shittttttty front brakes (im waiting on my q45 brake pads for the install) -clunking from rear (already replaced subframe bushings) -slave cylinder is shot -steering rack lines were leaking, and somehow some gook hardend around them and sealed them? wtf lol -needs new front radiator support pretty bad -clutch sucks, not too bad tho -SOHC ka with 167k, almost runs OK -needs paint, and pass fender -about 20 door dings throughout the car -wipers barely work -1 front tire is shot, another rim bent= bad vibration at 65 mph -license plate light doesnt work -1 headlight points at the ground, the other at the sky lol -shift knob is stripped muahahha i l0ve my car!!!!! edit: oh ya, my a/c doesnt work, nor does my defroster LOL |
#86 | |
![]() Join Date: Jul 2004
Leaking gas tank-Fixed
Stock 2" downpipe to a 2 1/4" highflow cat to a 3" catback-Fixed to 3" turbo back Blown sub frame bushings-Fixed Cracked windshield (I'm the one that messed it up )Fans don't turn on=car overheats if sits idle or in traffic Passenger side window still needs to get re-tinted Small tear in carpet Rear rubs when I ride on my 19"s Needs alignment EGT gauge not reading properly Damn rock chips on front bumper I think that's about it. Looking at getting the rest fixed soon.
#87 |
As an S30 driver I can say in fact that MY CAR HAS MORE RUST THAN ALL OF YOURS.
A leak from the tranny that won't stop even with new seals. Heater control valve that gushes water into cabin (currently bypassed). Defroster no workie. Glazed front rotors so the brakes squeal like I have no pads left. The Grand Canyon lives in my dash. Bad wiring under dash bypassed with wire nuts. But luckily my car doesn't have as much electronics as a S13, so less of that can go wrong...
Long live the Datsun Z. |
#88 |
My A/C blows too cold nomatter how close I slide the temp adjuster towards the red side.
Minor PS leak. Exhaust manifold gasket leak. Throwout bearing should be thrown out. Disintegrating shift boot. Cracked bushing on eBay STS; loose/sloppy shifting. 8 wheels, 2 good tires. New wiper blades, old wiper blade performance! Discount Auto Parts windshield washers - reservoir smells gnarly, they leak all over hood (despite proper installation), and can't overcome wind at speed to spray windshield. |
#89 |
Besides minor annoyances...not much.....until last week.
I had a PERFECT windshield on my 91 coupe. Literally perfect. But last week I was pulling onto the freeway when some truck came flying past me and cuts me off. He had 3 lanes of empty space beside him that he could have pulled into so I could merge. Instead he flys past me, and pulls in front of me, with his rock studded tires and puts 3 wonderfully large cracks right in my center of vision and another big smash right smack in the middle of the HUD display on my windshield. And one of my heater settings doesn't work...never has. |
