![]() Join Date: Dec 2001
Questions about Spacers..
If i get some 17's for my s13 with a 40 offset, what size spacers should i get to get them semi or fully flushed with the fender? I have a stock Sivlia conversion (no widebody)... let me know so i can order.. thanks!
Jose
RHD K's
![]() Join Date: Aug 2002
A 25mm or 30mm spacer will put you pretty close to flush with those wheels.
Ryan
17x7.5in 5Zigen 5ZR Copse, N1 Dual , K&N intake, PDM FSTB, Pilot RSTB, Whiteline Swaybars, KYB Struts, Intrax Springs, ACT clutch, B&M Short Shifter, Battle Version TC Rods |
Junkie
![]() Join Date: May 2002
Any reason why you don't want to just get some wheels with a good offset off the bat? You can probably convert to 5 lug and buy some nice wheels for a some more money and it will be more piece of mind than running spacers.
-Juan |
#8 | |
I'm getting a killer deal on these wheels and i don't have to be buying expensive wheels. Jose
RHD K's
![]() Join Date: Nov 2003
i can get spacers for about 100-125 a pop ranging from 15 25 35mm
www.AutoRnD.com Nardi, Enkei, Stance, AME Master Distributors for USA Check Out Our Facebook! |
![]() Join Date: Apr 2003
www.wheelspacers.com
does custom work, very very good ive heard about some bad experiences with H&R just fyi |
wheelspacers.com is the place to go. $65/spacer is reasonable considering the uber-high quality.
Also, just HOW FLUSH do you want it? If these were going to be used exclusively w/ these wheels, I'd get 40mm spacers. Otherwise (i.e. will be used with other wheels in the future) get either 30 or 35mm. I run 7" wide front with -1 offset without a problem, so you should have no problems running 7" rear with 0 offset. |
