![]() Join Date: Aug 2006
need help to pass smog. crank position sensor harness no clue
i have a s14 ka24de i checked my engine with a scanner and it told me i have 2 codes. 1st one was knock sensor and 2nd was crank position sensor. i changed the crank sensor thats all good now. now i bought a new position sensor. i cant seem to find the harness to it. where does it hook up to. the engine harness or the lower tranny harness does any1 know. also do u need a sub harness like the knock sensor has one. please help me
#2 | |
![]() Join Date: Nov 2006
What car is this in?
![]() Quote:
![]() Join Date: Sep 2005
what????? It should be tied in with the tranny harness 6th plug up from rear (including rear02 sensor)
![]() LoverTechnologies "Half Broken Things!" Last edited by cotbu; 09-19-2008 at 08:13 PM.. Reason: I'm just interpreting the FSM, I have an s13 |
#4 | ||
or he's using an s13 harness.... they dont come with a cps sensor on top of the tranny.
![]() Quote:
That, what???? wasn't intended for you, it was for the OP. I think he means, that he changed the knock sensor.... I know s13 don't, but if the engine is an s14 and the ecu is throwing a code for it, I just assumed it was an s14 tranny and harness.
I did assume it was a swap at first, but he was sort of specific and didn't mention if the old cps was connected or not... That's why i said I have an s13. To not be held liable for anything a type that may be stupid...
