1jz inside s13 experts needed inside!!!!!!
Ok here's my issue, the motor's in perfectly flush with the swaybar so it can't go forward anymore....
I have the ebay mount kit and heres how the trans lines up against the mount (yes i bought the OEM toyota supra mount but it's not installed yet).... even before i install the new mount it's no where near where the holes should be lining up....my question is....is the ebay trans mount crap or am i doing it wrong? any ideas on what im doing wrong or what i need to do?? Help would be great! Here's also where it sits on top.... |
I know i know, but i read good reviews and noone seems to complain... it's not the ebay kit the motor is sitting perfect. I know get it!
![]() Join Date: Dec 2006
Not sure how well the shifter hole is suppose to line up, but if the engine is sitting where its suppose to, it looks like the Tranny brace needs to be flipped around
![]() Join Date: Dec 2008
Trader Rating: (79)
![]() Feedback Score: 79 reviews
Doesnt look good, are you running a R-154 Trans? Is that the correct tranny mount for your tranny?
My Build: The "Coupe De Ville" 1JZ Build!! |
No if you see in my OP i have the correct mount but not installed.....BUT even when i put the correct mount in place it's still not even close to where it needs to be
bump.............
Figured out the issue..... it doesn't need to be flipped.... the problem is.........
On the 1jz/2jz block there are multiple mounting holes on the block and i mounted it too far forward....i feel stupid lol so basically i need to pull it out and move the engine mounts back. Sean @ myjzswap.com is a HUGE help! |
#14 | |
I'll post pics/start a build thread ones the motor is in place. |
