![]() Join Date: Sep 2012
FS S13 SR20DET built,GT3076,FullRace Header,Greddy IN Manifold,AEM Ems,ID2000cc inj
I have for sale a S13 Redtop Sr20det with a Z32 trans. It was used for 6 pro am events. Engine was rebuilt prior to it being used. Going for a different drivetrain setup so no longer need this. ![]() ![]() ![]() ![]() ![]() located in san diego 860-605-zero288 S13 Sr20det SOLD ALL engine parts were purchased BRAND NEW!!! Compression 160 cold Leakdown 10% cold Tomei 270 Cams hydraulic type Tomei adjustable cam gears oem rocker arms oem lifters Tomei valve shims/guides BC valve springs and retainers Supertech valve stem seals and guides Apexi head gasket New oem timing chain, chain guides, tensioner ARP headbolts CP forged pistons 86.5mm Eagle forged rods ACL race rod and main bearings AEM Ems Ecu Version 2 for sr20det SOLD Wiring Specialties Harness $350 Greddy Oil Pan SOLD not sure how these came new, but this one has oil temp sensor in bigger hole smaller one is the drain (check last picture) Garrett GT3076 AR.80 SOLD Full Race Exhaust Manifold SOLD Tial Wastgate with dump tube SOLD turbo coolant and oil lines, oil drain with an fittings SOLD Greddy Intake Manifold SOLD Greddy front mount intercooler $350 Nissan 68mm throttle body SOLD Injector Dynamics 2000cc injectors 11mm SOLD GM truck coilpacks, MSD plug wires, harness SOLD Sr20det alternator $50 Z32 Transmission SOLD Xcessive Manufacturing SR20det to Z32 trans adapter kit for s13 SOLD adapter plate, (brand new)starter, trans mount, driveshaft(non abs), shifter kit ACT Clutch 6 puck unsprung $400 flywheel included Last edited by AcceleratedMinds; 12-19-2014 at 06:20 PM.. |
#24 |
![]() Join Date: Mar 2011
![]() ![]() ![]() Feedback Score: 5 reviews
I want this....
Xcessive Manufacturing SR20det to Z32 trans adapter kit for s13 $500 adapter plate, (brand new)starter, trans mount, driveshaft, shifter kit is it for an ABS or NON-ABS differential? if it will work with either pm me your paypal. |
