Guest
Posts: n/a
I accidently ordered the cold versions of the denso irinium plugs. I was linked off of a japanese site so it assumed I had the 2.0 SRDET engine and not th 2.4. I was told I could still use them with my 2.4l...but should I? I heard it could misfire.
Guest
Posts: n/a
I believe hotter plugs are utilized for forced induction engines, therefore, the cold ones should be fine. Confirm this w/ a local autoparts dealer. It'll take seconds to answer...provide an update as I'm not 100% sure.
Guest
Posts: n/a
Ok I'll return them and get the hot ones.
If I were to put cold plugs in my NA S14, what would happen? I will be ordering my turbo kit soon after doing the plugs and wires. I want to get the plug that will work best with my turbo, but will it do any harm to put the cold ones in now? Or should I just wait until I get the turbo install done before I buy plugs? Id hate to buy the hot ones now, only to have to buy cold ones later.
Any ideas? (Edited by mrace240sx at 3:18 pm on Oct. 3, 2001) |
