S13 Starting Problem
I'm a relatively new S13 owner, although I am in my fifties.
My car isn't starting. The battery is good, and the dash lights up appropriately when the key is on, but nothing happens. No clicks, nothing. A friend crossed the terminals on the starter with a screwdriver, and you can hear the starter spinning then, but the engine doesn't turn or start. He thinks it's the starter solenoid. If I can get away with replacing the solenoid only, I'd rather do that. Anyone have some ideas or suggestions? Thanks. |
![]() Join Date: Dec 2006
sounds like ths starter solenoid.
try smacking the solenoid with a hammer while trying to start it If that doesnt work check for a 12V signal on the solenoid
![]() Join Date: May 2008
Look like the signal wire coming from the ignition switch doesn't receive voltage when you turn your key in the start position...
Check for voltage at the little rectangle terminal(single wire) that goes on the solenoid of the starter when you turn your key. Frank
Life is a beat to beat |
![]() Join Date: Jul 2009
#1 check your fuses under the hood could just be that
#2 check your battery and make sure the cables are connected on the right terminal neg to neg and pos to pos. My cousin put his battery in and connected the cables backwards (GM side terminal battery) everything would light up and when we went to start it all we heard was the starter solenoid spin, I noticed the terminals so we switched them and it started up |
| s13, starter |
