Old 06-01-2013, 04:01 PM   #1
Salley
Salley is an unknown quantity at this point
Exclamation Need advice-help ca18det
hello guys!
iv got an issue with ca18det lets see specs:
stroked ca18 til 2.0l
it has wiseco pistons and eagle rods inf from the old owner.
nothing done whith the head *sorry for my bad english im from norway
well turbo is +- bad.
+ valve ticking noise* he did changed the retainers so they are like max 2month old
first time i drove it it was like give a full gas on a 1 gear up until 4t rmp it did pretty bad then it got like a fuel cut came back to life and gone like a rocket
each gear allmost the same so i did changed the timing belt back to his marks...coz old owner did set it wrong after that it started to missfire i did the timing still same shit so at the moment it does do it better coz i changed a spurk plugs coils couple vacum pipes well it does got 2much gas cas stays all the way turned to the left" only place where engine does works bether
it has somekind of a chip its no mapp on ecu so rather i thing maybe i just need to get it mapped?
benn on a track today so in the swing rpm was bouncing on 4.5-5 rpm then came back and again works ((( well lets say its going not like it should until 4t rpm after that it goes well and coming black smoke from exhaust, adjust a little bit cas - no smoke engine loosing power...wtf
Salley is offline   Reply With Quote
Old 06-01-2013, 04:10 PM   #2
Salley
YEa and it does this thing you reach 4.5t rpm its start like bounce alilbit for a 4 secs somethimes i just take a foot away from gas then again on full throttle the it goes or just full throttle same it goes...as i sayed it has a bad turbo but it supose to go anyway
