Old 07-21-2012, 10:04 PM   #1
blackrb240
blackrb240 is an unknown quantity at this point
VQ35 Kouki
Before I begin, here's my old VQ build thread into a vert:
#/f/engine-tech/4328...-pictures.html
Here's how she looked when I traded her...
To a buddy of mine for this...
I told my self a thousand times I was gonna leave the car alone and just drive it. The SR was strong but had its little issues...so I started fixing things up a bit because dirty bays drive me insane. I removed the clutch fan, fixed the vacuum lines, built a new harness, and a few other bits to make her a little cleaner.
And I got rid of those stupid 19" wheels for something a little more tasteful.
Went to a few shows, did a few photo shoots, installed a sound system, and then this happened:
And this:
And then this a few weeks later:
Once that was all taken care of...
You can see the rod bearing damage on the #1 rod journal -______-
So this happened:
Once that was out, I rebuilt the brake lines, did some sanding/shaving, and a little painting. In progress:
Bought a '04 VQ swap from my buddy Kevin out of his Z...he wanted to make room for 8 cylinders in the near future so I took 6 off his hands. Lord it was dirty when I pulled it.
I cleaned the ever living &*$^ out of it and removed every single accessory, bracket, pipe, and pulley and cleaned them all in the parts washer before I reassembled the motor.
And here she is in the painted, uber clean bay
I have ALOT of work to do still on the car because I'm tearing it down to a chassis to make sure everything is right and reliable when I get done. The shifter and the driver's seat will be moved back 4" so I'll be more comfortable in my car when she's done. I am also planning on having a half cage built into the car, and build the mounts/wiring/exhaust/turbo kit. Progress will be slow but steady :/
Thanks to anyone who reads and/or follows!
blackrb240 is offline   Reply With Quote
