Old 09-19-2009, 03:35 PM   #1
bigjacsoc
bigjacsoc is an unknown quantity at this point
Thumbs up S14 BMC in S13
I have 180SX front calipers, Hawk HPS pads in front, Brembo slotted front rotors, and Goodridge SS lines front and rear, with stock rear calipers, pads, and rotors. Also I have an automatic brake booster.
I believe I've seen that the S14 BMC is 1/16" bigger than the S13 BMC and was wondering what the effects of having an S14 BMC would be with this setup. Like how much would it effect the stiffness/lockup?
bigjacsoc is offline   Reply With Quote
Old 09-19-2009, 08:19 PM   #2
Sileighty_85
Sileighty_85's Avatar
you relize none if the S13 lines match up to the S14 MC. Your better off using the Z32 MC if you wanna go bigger which i dont see the point, The I have a Z31 MC on my Full Z32 brakes, works fine for me.
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 09-19-2009, 08:31 PM   #3
projectRDM
projectRDM's Avatar
Only the automatic and ABS S14 cylinders are larger, and obviously an ABS one won't have the third port on it.
The Z32 is a direct bolt up for the S13 anyway, way easier.
FORMERLY R240NA
Old 09-21-2009, 11:41 AM   #4
Not You
Not You is an unknown quantity at this point
I wouldn't upgrade it with single piston brakes honestly.
Not You is offline   Reply With Quote
bmc, brakes, s13, s14, upgrade
