auto to manual tranny swap help
OK so i got my first s14 that has had a auto trans swapped to a manual now the from previous owner, and the speed gauge wont read the right speed when i drive about 10mph it says im doing 25mph so my question is. is there a differences between gauge clusters from auto to manual ones or is it something else like my speed sensor.
There is no difference between auto/man clusters. It may be off because of rear gear ratio change, larger tires or a combination of both. Do so more searching on here, there is a way to rectify the gauge reading on the cluster itself by soldering two connections together and unsoldering another.
My SR20VET |
