Old 05-23-2017, 07:50 AM   #1
1Badhatch
1Badhatch is on a distinguished road
ls1 swaps with ka radiator ???sss
Anyone who has done the swap in there s13 or 14 with a ka radiator can u take a coat hanger bend it to shape and give measurements of each bend so I can go buy the right hoses please
1Badhatch is offline   Reply With Quote
Old 05-23-2017, 08:23 AM   #2
smellslikecurry
smellslikecurry's Avatar
Trader Rating: (33)
smellslikecurry is close to perfectionsmellslikecurry is close to perfectionsmellslikecurry is close to perfectionsmellslikecurry is close to perfectionsmellslikecurry is close to perfectionsmellslikecurry is close to perfectionsmellslikecurry is close to perfectionsmellslikecurry is close to perfectionsmellslikecurry is close to perfectionsmellslikecurry is close to perfectionsmellslikecurry is close to perfection
Feedback Score: 33 reviews
http://www.enjukuracing.com/products...-hose-kit.html
or check this link for info on parts store hoses
http://www.silviav8forums.com/forum/...er=asc&start=0
smellslikecurry is offline   Reply With Quote
Old 05-24-2017, 07:13 AM   #3
onehundredoctane
onehundredoctane's Avatar
Be careful with the KA radiator on the LS swap. . . the inlet and outlet for the hoses being on the same side of the radiator means coolant doesn't spend as much time in the radiator.
If you can, go SR radiator since the inlet and outlet are on opposite sides of the end tanks.
Hope that makes sense. . .
Old 05-24-2017, 07:17 AM   #4
smellslikecurry
Trader Rating: (33)
If you absolutely want to stick with a KA rad, get a good dual pass one.
Old 06-06-2017, 10:03 AM   #5
shaggyjake
shaggyjake's Avatar
shaggyjake has made poor choicesshaggyjake has made poor choicesshaggyjake has made poor choicesshaggyjake has made poor choicesshaggyjake has made poor choicesshaggyjake has made poor choicesshaggyjake has made poor choices
I'm using a mishimoto KA rad on my swap. It's not really holding up to the task. The mishi design is supposedly a cross flow but it seems like a basic down low. The side with the inlet/outlet gets scalding hot and the driver side is almost cool to the touch. I've added an oil cooler, ceramic coated long tubes, and top cooling panels. Hopefully it works out. If you haven't already bought a new radiator, then check out this one:
http://www.optionsauto.com/prodinfo....KOYO-RH020539N
Koyo dual pass with inlet and outlet on the same side.
I plan on upgrading to this soon.
shaggyjake is offline   Reply With Quote
Old 06-21-2017, 11:59 AM   #6
mishimoto
mishimoto's Avatar
mishimoto is an unknown quantity at this point
Hello shaggyjake
I'm very sorry to hear that you have not been pleased with the performance of your radiator. If you need any assistance please contact us direct at [email protected] and we would be happy to help. Don't forget, every product we make is backed by the Mishimoto Lifetime Warranty.
Have a great day
-Jake
Mishimoto
Mishimoto Automotive
mishimoto is offline   Reply With Quote
Old 06-21-2017, 12:03 PM   #7
OutlawLui
OutlawLui's Avatar
wow interesting... never thought of that myself
good info
Old 01-04-2018, 11:28 PM   #8
Relentless240
Trader Rating: (50)
Relentless240 is an unknown quantity at this point
Feedback Score: 50 reviews
The koyo RH020539N looks nice. Too bad theres no
Npt built into tho. Even the sr20 Koyo has them.
Do the s14 fan mounts fit on this radiator?
Relentless240 is offline   Reply With Quote
Old 01-05-2018, 05:09 AM   #9
afishysilvia
afishysilvia's Avatar
Trader Rating: (30)
Feedback Score: 30 reviews
I have a Godspeed 2” KA Rad with mishimoto slim fans. I think the hoses depend on the kit. With my CX Racing kit like the one the OP has, there’s not enough room for any pre bent hoses. I’m using stainless steel tubes with odd ballends to make up the diff.
afishysilvia is online now   Reply With Quote
Old 01-05-2018, 06:31 AM   #10
alwaysnboost
alwaysnboost's Avatar
alwaysnboost is an unknown quantity at this point
I have a KA rad from Mishi on a built LS. NO issues at all.
alwaysnboost is offline   Reply With Quote
Old 01-05-2018, 06:46 AM   #11
afishysilvia
Trader Rating: (30)
You’re also New Jersey Area, which I bet doesn’t get close to the ambient temps on the west coast.
Old 03-07-2018, 03:24 PM   #12
cclark
cclark's Avatar
cclark has made poor choicescclark has made poor choicescclark has made poor choicescclark has made poor choicescclark has made poor choicescclark has made poor choices
I have the Mishimoto KA Rad and Fan shroud, with the Mishi swap hoses. I've fabricated the Mishi Water Temp Sensor Adapter fitting to bypass the LS steam port.
Check out my build: #/f/showthread.php?p=6248522
cclark is offline   Reply With Quote
Old 03-07-2018, 03:28 PM   #13
afishysilvia
Trader Rating: (30)
I have a Godspeed radiator with mishi slim fan and shroud. So far not impressed with it, need to play with fan speed and when they come on during tune then I’ll decide. For now I have an added SPAL pusher fan on the front.
