Old 04-12-2013, 09:19 AM   #1
MedHat240sx
MedHat240sx is an unknown quantity at this point
Redtop sr20 issue
recently i just through in a GT2871r .63 exhaust housing, a Exedy stage 2 clutch, external wastegate. the car idles, and drives fine exept when im coming to a complete stop it idles down to 400-100 rpm then just trys to die? what could be causing this i smoke tested my system and there were no vacuum leaks im hella stumped on it! any input would be most appreciated!
MedHat240sx is offline   Reply With Quote
Old 04-12-2013, 09:23 AM   #2
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Your blow off valve...
CLICK HERE!!!
Old 04-12-2013, 09:29 AM   #3
MedHat240sx
AHHH! that would make sense what would i half to do to fix it. its on my cold pipe and the moment and i did notice after i did switch the turbos that i got a rather large amount of compresser surge.
Old 04-12-2013, 09:34 AM   #4
fliprayzin240sx
Re-circulate it back to the intake tract, tighten the BOV, get better BOV that doesnt dump air too fast or just not run a BOV...your choice.
CLICK HERE!!!
Old 04-12-2013, 09:38 AM   #5
MedHat240sx
ill see if i can tighten it up, its a HKS ssqv so im assuming i cant, i wouldnt mind a greddy unit though ill look into it! thanks mang!
Old 04-12-2013, 09:12 PM   #6
fliprayzin240sx
You should be able to just tighten it. I hated my SSQ but they're actually one of the better BOV out there for MAF'd engines since they dont blow off to quickly if adjusted properly (if they're not leaking). Also, you can get a recirculate kit with it...which should fix your issue if tightening it doesnt help.
CLICK HERE!!!
Old 04-14-2013, 01:07 AM   #7
Srjustin
Srjustin is an unknown quantity at this point
I adjusted my idler control valve. It worked for me and car idles fine. I just wouldn't play with it too much. Also i don't think its recommend but it worked fine for me.
Srjustin is offline   Reply With Quote
