Old 09-27-2019, 08:57 PM   #1
S14rebuild
Question Sr20det with z33(350z) mass air flow aensor
So i know z32 mafs are like the big upgrade for sr20s. Was just wondering if anyone has used the z33 maf? Would it work(obviously would need a tune) and would it even be a viable upgrade?
Just figures its new technology.
Anyones thoughts?
Old 09-30-2019, 04:46 PM   #2
TheRealSy90
TheRealSy90's Avatar
Technically it could be used if the tune is adjusted for it. People have been using vr38 skyline MAFS on other cars for a while now.
Such a good signature.
Old 09-30-2019, 04:52 PM   #3
S14rebuild
Yea was lookn in to the r35 maf...just wonder if theres anything truly to gain to swaping to that or keeping z32 maf
Old 10-01-2019, 02:12 PM   #4
TheRealSy90
You aren't going to gain anything with a mafs swap other than more headroom for air flow than the stock mafs has. If the stock mafs is holding you back from tuning for more power then you'll want a mafs with higher flow capability. The mafs alone won't make the engine make more power.
Old 10-01-2019, 03:20 PM   #5
s13silvia123
s13silvia123's Avatar
For the guys who are using the PFC, you can use it if you switch the maf calibrated for the Z33-z34 and the R35. they same part numbers. yes you can use them and its it been down for awhile now.
Old 10-01-2019, 04:26 PM   #6
S14rebuild
Gain as in more head room(voltage fluxs) compared to z32
But was already told to keep the z32 maf
Old 10-01-2019, 04:43 PM   #7
TheRealSy90
Kind of. All nissan MAFS output 0 to 5 volts across their flow capacity. 5v at the max airflow it's calibrated to measure. Also, the voltage output is not linear in relation to the air flowing through the meter, instead is exponential as the flow increases. Technically the sr20 mafs has a higher resolution across those 5 volts, in comparison to a mafs that can read 2 to 3 times more air flow across that same range of 5 volts.
But TLDR, yes a higher flow rated MAFS has more headroom before it reaches that maximum 5v output. Though it won't be as accurate at lower cfm's.
Old 10-01-2019, 06:27 PM   #8
S14rebuild
Yea, i just was wondering if any of the other mafs could support more horsepower over a z32.. but ill just stick with the z32
Old 10-02-2019, 08:17 AM   #9
jedi03
based on my initial conversations with martin from enthalpy the maf isn't the limiting factor for HP
Old 10-03-2019, 01:22 AM   #10
Kingtal0n
Kingtal0n's Avatar
You want the smallest maf you can possibly get away with if using the car to drive normally on the street type of setting where low rpm(low flow rate) resolution is important for drivability and economy.
In racing you want to eliminate the maf completely to free up intake pathing and remove obstruction, & potentially small pieces of plastic and potentially leaky areas from the plumbing, thus simplifying the setup.
For sr20 engines below 500whp on the street a Z32 maf is ideal, good enough resolution for normal driving and high enough potential power output scenario, using PFC I am on the final line row #20 approaching 450rwhp (500-520bhp) with that maf
https://www.youtube.com/watch?v=yu7XteLyuVA
