#2 | |
![]() Join Date: May 2009
Is the motor mount OEM? OER and aftermarket are not necessarily going to be the same. I know some of the autozone ones come with new nuts and oem ones will not fit. Easiest and fastest way to get this info would be to take the mount out and go to the hardware store if you don't end up getting the answer you want here.
