Where is the Power Steering Fluid Reservoir
I've never had to add power steering fluid in my 240 but now I have to and I can't figure out where the reservoir is. I can see two reservoirs besides the brake fluid but both have no indication as to what they are for. Your help will be appreciated. What does the cap have printed on it and where is it? This is for a ka24de. Thanks again.
![]() Join Date: Dec 2002
It's the one that has hoses leading from it to the steering pump and rack.
Seriously???
oh man.
its in front of 2 you seen, on strut tower on right if looking at engine bay from front. Its greenish brown. about the size of a small peanuts can, black cap. you can use atf. also, if you look at the parts you see, you can easily look at the lines / hoses and figure it out. I beg you to try harder. Its clearly connected by a hose 2 feet long. Good luck bro. TRY HARDER~ please. your family needs you to be smart. be smart. |
Sorry guys, problem was that I just bought my second 240 and the engine bay is so greasy that you can't really see where any hoses end. I added fluid but it still dosen't soften up. I'm also degreasing the engine right now.
And retighten all the clamps. They like to loosen up over time.
![]() Join Date: Feb 2007
To the OP, I have gone through 2 power steering pumps in the 200+k that i've owned my car, so make sure the pump is even working properly and that the lines are not leaking. Even a tiny leak can get air in there, so check hoses/clamps too like projectRDM said.
![]() Join Date: Oct 2007
Trader Rating: (53)
definitely a good suggestion. i would even go as far as replacing all of the clamps that you are willing to dig for on the P/S system. i know my car came with those shitty clamps that look like 2 wires and a screw and they dont hold anything very securely. i replaced all of them and now my hoses are good to go
#11 | |
![]() Join Date: Sep 2004
Wayne |
