#62 |
![]() Join Date: Oct 2004
Tell that to every single pre 1972 show car owner.
high performance driveway photography zenki s14---v8 fc rx7 my crappy flickr page (drift cars whoo) |
#63 |
![]() Join Date: Sep 2005
Those aren't really driven around and subjected to rocks and stuff are they though?
1989 S13 | 1996 S14 | 2001 E46 | 2009 ZX6R
#64 | |
![]() Join Date: Jan 2008
These day true show cars only have about 2-3 coats of clear. originally they may have put on around 7-8 coats but they do it in stages where they keep on color sanding it into finer grits till the clear perfectly flat as glass. I've done this on one qp to experiment. It works but alot of $ and time. |
#65 | |
professional/production guns that are made to be designated guns run from 230-800.00. My best gun cost me 350.00. Its an iwata and i love it compared to all the guns i've used. good companys in my list is:*the last 4 only offer basic beginner guns* satajet anest iwata devilbiss(almost or as good as iwata) graco binks accuspray |
#66 |
Looks decent... But for $500 bucks I'd rather take the shit to Earl Scheib and have them do the work. I did that on my 240, the paint job came out great, it was a 24 hour turn around, and it came with a lifetime warranty.
$500 = metallic paint (black with gold pearl)/ color change of door jambs, trunk jamb, underside of trunk lid, etc, everthing but engine bay. ![]() Shitty pic. But you get the idea.
#67 | |
![]() Join Date: Nov 2004
#68 |
![]() Join Date: Apr 2006
![]() this is with no sanding, or anything. havent washed it sinc ei painted it either
2015 Subaru Outback Overlander - Wagonofdoom |
#72 |
Just a random white paint from the store, house of color fusha flakes in clear, then more clear
#73 |
![]() Join Date: Nov 2006
Trader Rating: (54)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 54 reviews
lol didn't mehsilvia post a $300 DIY Paint Job thread in the premie section?
That paint does look pretty cool though. ![]()
- Jimmy Wanted: TBD For Sale: TBD |
#75 |
![]() Join Date: Jun 2007
Just say yes to rattlecan... My wagon is le shit. I kicked a hole through the rear 1/4 panal today though... lol a little more rusted then I thought.
BRAND NEW GReddy PRofec E-01 EBC for sale, Cheap! |
#76 |
![]() Join Date: Aug 2006
Trader Rating: (40)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 40 reviews
id rather have my 2 year old daughter finger paint my car in that case
things may come to those who wait, but only the things left by those who HUSTLE CLICK HERE FOR MY BLOG |
#77 |
500 bucks. That's about the same as going to Maaco and having them do it.
Your call though. ![]() Looks awesome btw.
1986 Porsche 944 Turbo (951) 1995 Nissan 240sx (S14) Miss ya. |
#78 | |
![]() Join Date: Jan 2005
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 6 reviews
and you dont get the honor of saying you did it yourself. +maaco is not going to do a better job than you are. As for myself, I rather learn how to do things on my own. Painting is really time consuming and this is why shops charge so much. The paint process is the easiest part. Stop rattle canning your cars. They look like garbage. I use cheap guns and get great results. This gun is from harbor freight and for the standard gravity feed gun is $14.99 WTF. The HVLP gun runs $49.99. I use the gravity feed for primer and the HVLP for base / clear. I do get great results, but with any DIY garage job there will be some imperfections that will have to be sanded and buffed out. ![]() Another $250 dollard job. This materials, primer, reducer, paint. Single stage white: first car I ever painted. I first rattle canned it $65 dollards and after coming out like shit I went out and bought single stage paint for $100 and it came out like this. And here is the latest car I painted. You can also see my fan set up. I usually install an ac filter to aid in overspray. I also use 10x20 drapes from lowes paint department.
1994 FD3S Drift // 945garage // sumospeed.com
#79 | |
#80 | |
#81 |
![]() Join Date: Dec 2007
![]() ![]() ![]() ![]() Feedback Score: 16 reviews
grant. we ARE painting my car when i finish the swap and get aero.
dam, reading all this diy shit just makes me want to sell a kidney and get all my shit done in 1 weekend. ha
Banana boat chronicles |
#83 |
I have a detached garage FTW!!!!!!
I dont think the fumes will creep that much into the house. Using an HVLP gun will minimize lots of over spray also. Try to use some kind of fan to move the fumes outside of the space you are working in. I decided to go this route because it was better than spray paint, I can change colors when ever i wanted, fix driftscars, and learn something new.
#84 |
![]() Join Date: Apr 2008
when i painted in my garage the fumes didnt penetrate the house. Also if you leave the bottom of your garage door open and then open the outside access door open it makes a weak cross draft booth.
Paint fumes are heavier than air so they sit on the ground and accumulate. Be sure to turn off your water heater and clothes dryer if its in the garage, you dont want any fires! |
#85 |
![]() Join Date: Oct 2006
Trader Rating: (26)
ok i got a question
what outside temp should you paint it? and say im going to paint in my garage but its like 40 degrees outside how can i heat up the garage? |
#86 |
I use 2 kerozyne heaters for pre-warm up. I cant remember the BTU's I use, but I pre heat the garage for an hour. Turn them off when I start spraying and then turn them back on when I'm done. I just finished my last car and it came out great for 40 degree weather. I'm done unttil it gets hotter though. I painted a few cars and all of the sudden I had people asking me to spray their cars. A little side money doesnt hurt
#87 |
idealy u you want around 70-80 degree's with zero humidity but yeah u might want something to heat up the garage. At 40 degrees your paint will be hella cold and so would the surface of the metal of the car. Youll have a good chance of running the paint or not letting it flash off enough to where your gonna trap solvents in between coats and have issue down the road. I would get like 2 10,0000 btu heaters and if u can control the temp of the garage. If your lucky get another like oh idk 30-40,0000 btu and when u are done painting bake that garage upto 130 degree's. Your paint will cure in about 20-35min lol.
as for the fumes they shouldnt get into the hosue unless u have vents or ducting that goes inside the house or ur house is so old that they sneak through all the cracks. Get an intake somewhere to bing in fresh air and an exhuast to keep the fumes/over spray away from the car and you. yuris made a good point on the heater and everything. Turn those off or could possibly blow ur urself in there or have a flash fire. another thing is try to get explosion proof lights. The fumes can ignite from those too. and if u cant do anything of this then ask around u and see if someone will rent you out a paint booth and make sure its heated so u can control the weather.Fortunely i have access to one booth thats a cross draft for pretty much free but in the winter i dont like it and i have access 3 down draft booths. 2 are infrared heated and 1 is force heated with a furnace. |
#89 |
![]() Join Date: Oct 2002
grant...want to practice on a multi colored 180SX????
also, if you know anyone looking for a cheap ($1500) 180...let me know.
Marc - Yokohama, Japan |
#90 |
Trader Rating: (26)
silpena do you think this is a good gun to start with
DeVILBISS FinishLine 3 Waterborne HVLP SPRAY PAINT GUN - eBay (item 190267432252 end time Dec-16-08 13:55:53 PST) oh and will this work ok for air/ water http://cgi.ebay.com/ebaymotors/2-OIL...motiveQ5fTools |
