Comp Turbo
Has anyone on this forum been to Comp Turbo in Pomona Ca.recently for a turbo rebuild/repair. If so how was their work and service? Looking to get a rebuild done? Any positive or negative comments?
Thanks Sent from my iPhone using Tapatalk |
Comp turbos are awesome i would suggest you ditch your turbo and go with one of their triplex ball bearing, aluminum center cartridge, X-HF wheel turbos super fast spool and make great power sold my 5562 to a miata guy fully built 1.8 and he spools 14 psi under 4k high 3xxwhp
#3 | |
Thanks for they reply. Question was regarding if you have had a rebuild done there. If anyone can advise on the question please do.. Thanks Sent from my iPhone using Tapatalk |
So this place did a "rebuild" on my stock t25, After installation process it began to make this whistling noise at 3k rpm and sounded worse any higher. took the Turbo back for warranty review. Long story short they said the core was damaged and they want me to pay additional monies(half of what the cost of rebuild was) to fix it.
If possible do not bring them any business, just stay away from their "services." Sent from my iPhone using Tapatalk |
