#3062 | |
![]() Join Date: Jun 2009
#3063 | |
![]() Join Date: Jul 2007
Trader Rating: (18)
'92 HB HX35 rb25 - sold '89 Coupe GTX35 VVT-I 2JZ - yeah buddy |
#3064 | |
Trader Rating: (18)
I do have the back housing I could sell you if you're interested. You would just need to buy the bypass tube that runs from the upper coolant outlet down into the water pump. THIS Welcome to Driftmotion!
#3067 | |
#3068 |
So I found a new engine importer in Gaithersburg, MD called MD JDM Motors. I have to say, being able to see the engine in person was a big help. I went looking for a normal 2JZ, but I ended up getting a VVT-i 2JZ. Good news is it came with the Ignitor and the MAF, bad news is the immobilized ECU. I'll just have to get an older one, no big deal.
As you can see, I don't have the best place to work on the engine, as I have no garage. But at least it's airtight, will stay dry, and I plan on keeping a dehumidifier in there just in case. Working on taking the stock twins off to get rebuilt as of now. If anyone needs an A341e, torque converter and Flexplate for cheap, let me know! I don't want it haha
Daily: '99 Pontiac Trans Am. Projects: '96 S14, '87 Merkur XR4Ti |
#3069 |
![]() Join Date: Jul 2013
Hey guys, got a question for you people out there with 2jz swapped s-chassis. I got a 95 s14 2jz swapped with an R154 and my clutch pedal acts weird. When it's cold it engages right off the floor and sometimes it doesn't allow me to even get into gear, but when it's hot it engages almost all the way out. I replaced my slave cylinder and it still does it. Anybody have any idea what could be happening? It still uses the stock hardlines and master cylinder. Please PM me!
#3070 | |
Looking for good conditioned 2jzgte swap parts for 240sx s14! |
#3071 |
Sadly im pondering the idea of selling my swap and maybe even s14 before i get it finished. Getting a little more mature and thinking about getting a classic celica. I dont get to drift regularly and it would be nice to drive a car that you dont have to worry about getting stolen(as much). What do you guys think i could get for my swap & car??
Aristo 2jz W58 Stock twins New Clutch and slave cylinder New OEM Head Gasket New ARP Headstuds(resurfaced) New Oil Pump New Xcessive Mounts New Wiring Specialties Harness New Ebay Downpipe White 95 s14(clean minus primer rear bumper) PBM Coilovers(less than 500miles on them) 5lug w/ Zbrakes & steal braided lines 18x10 XXR 521 ISIS rear links Megan Type 2 exhaust PBM high mount intercooler Welded Diff Walbro New subframe bushings(not installed) Just curious what you guys think AS FAR AS PRICE. Still not sure if i really wanna sell yet |
#3072 | |
#3073 |
Anybody running a 4" down pipe and exhaust?
I'm debating running 4" straight pipe all the way back. ATP turbo has a 3" to 4" modular downpipe that could make this pretty easy: 4" Modular Downpipe with 3" V-Band : atpturbo.com
S13 XE coupe: Aristo GTE, R154, GT37, Defsport Wilwood kit, KTS coilovers |
#3074 |
Good point. All I really need to do is put the motor back in and get intercooler piping made. Everything else would be odds and ends, nothing major
#3075 |
i picked up a usdm 2j water pump for my 1jzgte swap. do i still need the rear thermo housing too? or is a bolt on application with the jdm thermo housing. i know i need a pulley just curious if i need the back housing? thanks!
Zenki s14 1 J Z- G T E |
#3076 | |
![]() Join Date: Jan 2007
*Just buy the ebay 4" downpipe w/midpipe (got mine for $200-250 together).
93 s13 Vert - 2jz/cd009 -- parted/sold 95 Supra Turbo |
#3077 |
ATLspeed, do you have any pics?
I was thinking 4" oval would make a lot of sense so the exhaust could be tucked up nicely for a low car.
#3078 |
![]() Join Date: Jan 2012
Im also going to be running 4in all the way back. Ive talked to a few people, said the ebay supra downpipe is a pretty good fit.
Ill be using the xspower 4in downpipe/midpipe. Be told have to mod the midpipe some. |
#3079 |
![]() Join Date: Jan 2009
Never posted up on this but I bought a 1JZ earlier this year in March from Dallas JDM Motors. Got a great deal shipped. Just know it was GOOD. lol. Tore it down a bit and ordered stuff off Driftmotion like the gasket set to do a slight refurnish, ARP Studs, Precision 5831 T3 Turbo (I know, not a T4, but got a good deal on a brand new one), 550CC Supra 2JZGTE Injectors. Replaced broken things on the motor like the TPS and pulleys (Dallas JDM motors covered the pulleys).
Power goals are mild starting around modest above stock 350-400. I plan to get a 2J bottom end after this is done and assemble 1.5J when it comes time. Estimating completion around Feb 2014. Haven't had much time to really mess with it because I'm working a lot. - JZX90 1JZGTE - R154 Transmission - Manual ECU - Driveshaft ![]() ![]() Current Parts list - ARP Head Studs - New Gator Timing Belt - USDM Supra 2JZGTE 550CC Injectors - USDM Supra 2JZGTE Water Pump - New OEM Crank Pulley (sent free w/ motor) - Driftmotion Lightweight Pulleys (sent free w/ motor) - Precision 5831 T3 Turbo - Aeromotive FPR - NEO AFC Haven't decided on a clutch, unsure what to get. I want something that is usable and won't blow slave cylinders or do funny crank walks (Saw the ACT thing, that's scary).
#3080 |
Trader Rating: (18)
Clutch masters clutches have an almost stock pedal feel. That's what I'll be using.
Good choice with Dallas jdm. I got my vvti 2j from him a few months ago. Zund is a cool dude. I drove up there and they compression tested it right in front of me.
#3081 |
He is a stand up guy. Love his positive attitude and referred a few friends to him. How much HP is the clutch masters one? I want something that will bite hard and react when clutch kicking as this will be mostly for my street/track build, but something that's not stupid where it's not drivable on the street.
#3083 | |
this is really only the picture i have ![]() |
#3084 | |
Trader Rating: (18)
The cheapest dealer on this forum I have found it so far is importimage.
#3085 |
Thanks man. Yeah, I was worried about replacing slave cylinders. Had to do that on my SR20 ACT 6 puck every like few months because it was so stuff it would blow the cylinder out and round off the edge.
#3086 |
*Knock on wood*
I've had the act clutch on my r154 + aristo gte swap since 2008 I think. No issues so far...
S13 XE coupe: Aristo GTE, R154, GT37, Defsport Wilwood kit, KTS coilovers Last edited by Black R; 11-13-2013 at 10:09 AM.. |
#3087 |
Which ACT setup do you have? From what I understand, the crank walking is caused by the tougher of the pressure plates they offer.
#3088 |
^ Sadly I have no idea.
I know it's held over 400whp and tons of drag strip and street abuse though... The pedal doesn't feel that stiff... I'm aware of the crank walk issues that are caused by super stiff pressure plates; but haven't had any problems yet. Speaking of which: how hard is it to replace the crank thrust washers?
#3089 |
May be a stupid question.
Im new to 240sx's came from supras and recently got confused from all the different types of 240sx's and 180sx's soo... Will everything listed work for an s13 240sx?
#3090 | |
Trader Rating: (18)
The crank walk problem is almost eliminated by bypassing the clutch switch so you can start the engine without pushing in the clutch. If you push in a heavy clutch with the engine off, it tends to push out the remaining oil that was held between the the thrust bearings and the crank/block which causes a dry start for the thrust bearings and can eventually wear them down enough to cause failure.
