![]() Join Date: Dec 2011
Q45 diff
Do I have to get 96-01 diff to fit in the s14? I tried searching online about the dimensions but couldn't find anything. What's the different between 04 diff and the earlier model diff? Is the pumpkin different? Final drive ratio?
![]() 'Born Ready!',LJ |
From what I understand the pre 1996 diff will fit in your car as well. The housing is the same but the ratio is different. The pre-96 had a ratio of 3.54 and the post-96 had a ratio of 3.69. I don't know anything about the newer q45 diffs.
Sr22 in the works |
![]() Join Date: Apr 2003
Trader Rating: (33)
90-96: Need larger wheel hubs like the Z32TT, Z32 TT driver side axle, Q45 driver side axle. This has a 3.54 ratio.
97-01: Uses stock stock S14 vlsd equipped axles or J30. 3.69 ratio. |
#10 | |
![]() Join Date: Aug 2013
Found this, I think the 04 use the R230, so I am incorrect.
