SR20 won't start! Halp!
So I just bought an S13 with an SR. It was running fine and made the 140 roundtrip drive to work for almost a week, just fine. Well after getting back into town yesterday, it was running fine when I pulled into the car wash. After I washed it (self serve car wash), I started it and it began to run on only or 2 cylinders. I figured something just got wet so I turned it off and popped the hood to try and figure it out. I did everything I could with the resources that I had, then called one of my buddies because I couldn't figure it out. He messed with it a bit trying to figure out what was wrong by process of elimination. We eventually got it towed to a busy of our as shop. We liked at it tonight and tried/did a few different things. Switching out the ecu, changing spark plugs, checking the CAS, checking spark, regrounding the battery and motor, checked for fuel delivery, checked the ignitor/ignition but still no luck.
We are short of at a loss. Any help would be greatly appreciated guys! |
![]() Join Date: Jul 2005
what were the results of the spark test? Do all cylinders spark?
Do a compression test, check the fuel pressure, check for spark on all cylinders, spark/fuel/air should cover it |
Spark is good, as well as the fuel pressure. Haven't done a compression test yet, but we will probably check that when I get off of work. Would bad compression on one or more cylinders cause it not to start? When I blew rings on my KA-T it started but smoked really bad.
![]() Join Date: Sep 2005
Bad compression in one cylinder will not cause the engine to not start it would have to be all cylinders or zero compression.
Sure there's probably a combo but either way you still wont start. Spark, Timing, air, fuel and compression. Sent from my LG-H631 using Tapatalk
