![]() Join Date: Feb 2002
Enjuku Racing - ISR Performance - S13 Engine Gasket Kit $65 (no headgasket)
Summer Clearance!!! ISR (Formerly ISIS) Performance OE Replacement Engine Gasket Kit - Nissan SR20DET S13 ![]() Limited quantities at this price, hurry and secure your kit! This kit fits S13 SR20DET only. Kit Includes: (excludes headgasket) ISIS Performance OE Replacement RWD SR20DET Rear Main Seal ISIS Performance OE Replacement RWD SR20DET Front Main Seal ISIS Performance OE Replacement RWD SR20DET Intake Valve Seals ISIS Performance OE Replacement RWD SR20DET Exhaust Valve Seals ISIS Performance OE Replacement RWD SR20DET Timing Chain Tensioner Gasket ISIS Performance OE Replacement RWD SR20DET S13 Valve Cover Gasket Set ISIS Performance OE Replacement RWD SR20DET S13 Intake Collector Gasket ISIS Performance OE Replacement RWD SR20DET S13 Intake Manifold Gasket ISIS Performance OE Replacement RWD SR20DET S13/14/15 Exhaust Manifold Gasket ISIS Performance OE Replacement RWD SR20DET Turbine Inlet Gasket (4 bolt) ISIS Performance OE Replacement RWD SR20DET T25 Turbine Outlet Gasket (5 bolt) ISIS Performance OE Replacement RWD SR20DET T25/28 Compressor Outlet Gasket (3 bolt) ISIS Performance OE Replacement RWD SR20DET Oil Pick Up Tube Gasket ISIS Performance OE Replacement RWD SR20DET Oil Pump Front Cover O-Ring ISIS Performance OE Replacement RWD SR20DET T25 Turbo Oil Drain Gasket ISIS Performance OE Replacement RWD SR20DET Oil Filler Cap O-Ring ISIS Performance OE Replacement RWD SR20DET S13 Throttle Body Gasket ISIS Performance OE Replacement RWD SR20DET Side Feed Injector O-Ring Pack inc FPR ISIS Performance OE Replacement RWD SR20DET Cam Angle Sensor O-Ring ISIS Performance OE Replacement RWD SR20DET S13 Idle Air Control Valve (IACV) Gasket In Stock and Ready to Ship! $65
