![]() Join Date: Nov 2007
that looks like the hose that connects from the intake manifold to the brake booster. 1 of 2 hoses. if its cracked it can cause idle problems and afr problems.
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180 |
i retract my statement, i believe you're correct with it being the heater hose. It carries coolant through the heater core on the other side of the firewall. shouldn't be tough to resplace. good luck
i suppose you could just go to your local kragen/ krack zone and get a similar looking hose and bend it to suit your situation.
