![]() Join Date: Apr 2009
Trader Rating: (24)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 24 reviews
FT: 93 240sx loaded with mods.
*****Update 3/4/21 . Still have this car. Turning 52 this year and looking to get out of the 240 scene. Since putting this car up for trade 8 years ago, some things changed. Car has never been beat on. (2 old for that stuff.) Built the car just to build it. Have any questions just ask. I will do my best to answer them.
4/13 ***** Note ***** Im getting several PM's asking for a cash price. Adding up what I have spent on the car totaled $28,000.00+. That was just for parts, labor not added in total. Spending another $600.00 getting the GTR seats redone. I'd MUCH rather trade the car as stated in my post. Im not sure how to go about putting a cash value on it. I'd be better off parting the car out if cash was what I wanted. So as for now, trade only..... Thanks... Trade must be equal in value/mods or close to it. (JDM light up tag does not come with car.) *********** Some cars/bikes that I would be interested in, but not limited to: -Classic Mini Cooper -Classic American made car (Just picked up a 65 Ford Galaxie, but will consider another classic. -Datsun 510 -Subaru Impreza RS with turbo STi swap. (Maybe. Already have a 07 STi.) -s13/s14 with a RB swap. (May just sell my motor and do a RB swap.) -Aprilia RSV 1000 HAGA Replica. -Boat (Go fast boat. No Seadoos, have 4.) ***** Here is the car I have to offer in trade**** 1993 Nissan 240sx Modification list: General Info: -1993 Nissan 240sx -Coupe -Base Model 240sx. -Aztec Red -200,00 miles on chaises -3000 miles or less on all Aftermarket/ Performance parts at the time of posting this ad. (Miles go up since I still drive the car.) -3000 miles TOTAL on sr20det rebuild. (At the time of this ad posting.) Engine: (Built SR20det Black Top) -R.S. Enthalpy Tune w/ 2 Step Launch Control -Nissan Z32 MAF -Turbonetics 60-1 turbo -Wiseco Pistons -Eagle Rods -ARP Main Bolts -ARP Head Bolts -HKS Rocker Arm stoppers -HKS Step 2 Cams -Cosworth Head gasket -Greddy Valve Springs -Greddy High Capacity Oil Pan w/ Peak Performance Oil Drain Plug. -Greddy Oil Catch Can (Machined 3 piece.) -Greddy Oil Filter Relocation kit (K&N Oil Filter used.) -Greddy Replica Polished Intake Manifold -Greddy Oil Cap -Turbo heat wrap. -Tial 38mm Wastegate (12lb Spring.) -Kinugawa Oil Feed Line -Circuit Sports Aluminum Pulley set -Circuit Sports Aluminum CAS Cover -Top Speed Engine Torque Damper -Spectre Oil Filter Cooler -Candy Blue Powder coated Valve Cover Engine rebuilt with: -Nissan OEM Timing Chain Kit -Nissan OEM Water Pump -Nissan OEM Oil Pump -Nissan OEM Main Crank Bearings -Nissan OEM Rod Bearings -Nissan COMPLETE OEM Gasket Set -Head Surfaced & Cleaned -Blocked Decked, and Cleaned Ignition System: -Splitfire Direct Ignition System -Circuit Sports Ignition Coil Ground Plate (Coil Pack Cover.) Car Cooling System Set up: Engine: -Koyo Aluminum Radiator -Greddy Radiator Cap -Powered By MAX Coolant Swirl Pot. -Flex-a-lite Electric Fans -Flex-a-lite Mechanical Fan Controller -Samco Upper/lower Radiator Hoses -Stance Water Neck Adapter. (Temp Gauge Sensor Adaptor) -Nismo Thermostat -Circuit Sport Aluminum Over Flow Tank -New OEM Temperature Sensors. -Turbo: -Pre Turbo Oil Cooler (Custom set up.) -Custom Made Oil Lines. -Power Steering: -Power Steering Cooler -SPAL 4" Electric Power Steering cooling Fan. 124 CFM Rating @ 1.9amps (Have, but not installed.) Oil Cooler: (Have but not installed.) -Greddy remote oil filter adapter with Thermostat. -Tomei 193068 N2 Super Oil Block Adapter -12 Row Aluminum Oil Cooler 13.5" (L) 2"(W) 8"(H) -6" Oil Cooler Electric Fan. 300 CFM Rating @ 4.8 Amps -AN 10 Fittings through out. -Stainless Steel Braided lines. -Aluminum Hose Separator Fittings for Braided lines. Intake/Intercooler Set Up: -K&N Air Filter (RU-2520) -CNC z32 Filter Adapter -BMPC Bar & Plate intercooler -Polished Aluminum Piping, Sections of IC Piping Custom made. -DEI Cyro2 Intercooler Sprayer Kit. (Kit #080108) (Have, but not installed.) -DEI Cyro2 3" Cryogenic Air Intake (Kit #080110) (Have, but not installed) -HKS SSQV Blowoff Valve (Super Sequential Blowoff Valve) -T-Bolt Clamps through out. (Stainless Steel.) Exhaust: -CXRacing Top Mount Manifold (New Design.) -Custom made Turbo Exhaust Pipe (Titanium Header Wrapped.) -Custom made Wastegate dump pipe. (Titanium Header Wrapped.) -Megan Racing Down Pipe -Megan Racing 3” Test Pipe -New Nissan OEM o2 Sensor -Apexi N1 3” Cat Back Exhaust -Apexi 155-A031 Titanium Slide Tip for N1 Turbo Muffler -Circuit Sports Exhaust Hanger Bushing Kit (Set of 3) Drive Train: -Nismo Motor Mounts -Nismo Transmission Mount -Fidanza Aluminum Flywheel -ACT HD Street Clutch Kit -Stainless Steel Clutch Line -Aluminum Drive Shaft -J30 Rear End -NEW Clutch Slave Cylinder Fuel System: -Power Enterprise 850cc Fuel Injectors -Walbro 255 Fuel Pump -Aeromotive Fuel Pressure Regulator w/ Gauge (Oil Filled.) -300zx Fuel filter -Circuit Sports CNC Machined Aluminum High Flow Fuel Rail -Stainless Steel braded Fuel lines w/ AN Fittings Suspension: -Tein Flex Coilovers -Tein EDFC (Electronic Damping Force Controller) -Tein Front Strut bar -Tein Rear Strut bar -Tanabi Front Sway bar -Tanabi Rear Sway Bar -Tanabe Sustec Front Underbrace -Yamato Garage Complete Multi Link Suspension Arms (Custom powder coated in Tein green.) -Energy Suspension Bushing kit (Where applicable.) -4 Wheel alignment performed by Vortex Motor sports Brake System: -300zx Master Brake Cylinder (z31 Remanufactured) -Brembo 4 Piston Front Calipers ( 2005 Evo 8) -300zx Rear Caliper (z32 remanufactured) -Slotted/ Drilled Front Rotors -Wagner Front Brake Pads -Brake Motive Cross Drilled/Slotted Rear Rotor -Evolution (brand) Ceramic Rear Brake Pads -Circuit Sports Stainless Steel Brake Lines -Megan Racing brake master cylinder heat shield Interior: -Godspeed 6 Point Roll Cage AEM Gauges: *True Boost, Controller/ Boost Gauge *Wideband Meter *Oil Pressure *Water Temperature *Voltage - ATI ezPod Steering Colum Gauge Pod -Aluminum Center A/C vent Gauge Holder. -Blitz JDM VGTT (Voice Guide Turbo Timer) -Pivot JDM Shift-light (Model ASL-X ) -Nissan Skyline R32 Seats -MOMO Mod 80 Steering Wheel -NRG Hub (Black) -NRG Quick Release 2.5 (Blue) -NRG Hub Lock (Black) -B&M Short Shifter -Custom made suede like shift boot -GReddy Counter Weight Shift Knob -Broadway Mirror -Nissan OEM Fog Light Switch (Hard to find.) -LED interior dome light. Body: -OEM Color Paint Job Using Nasen Paints: *Complete Body Paint *Engine Bay *Door Jams *Trunk Jam ***Silvia Front End Conversion*** -B-Wave Front Bumper (JDM) -Chargespeed Rear Bumper -Chargespeed Side Skirts -Chargespeed 20mm Over front fenders -Chargespeed Drift Hood (Fiberglass) -AeroCatch Hood Latch 120-2100 Plus Flush With Lock Kit -JDM s14 Kouki Wing (Custom Modified to fit.) -Silvia Brick Head Lights -NEW Silvia Head light Brackets -NEW Silvia Corner lights -NEW Silvia Half N Half Signal Lenses -Silvia GT-R Grill -Silvia Trunk Lock -Origin Roof Spoiler -Rear Fender Pull (Performed by S&R Performance) -AeroCatch Hood Latch 120-2100 Plus Flush With Lock Kit. ***Note: The ONLY parts purchased USED for the Silvia conversion was the Silvia Brick Headlights, B-Wave front bumper & Grill. All other parts were purchased brand NEW. Wheels: -Rays Engineering Gram Lights 57F *FRONT 18x8.5 +30 *REAR 18x9.5 +20 -Tires *FRONT 225/40/18 *REAR 255/35/18 -5 Lug Conversion (Rear z32 hubs, front Ichiba hubs.) -Muteki lug Nuts, Closed End Stereo: -Alpine CDA-7894 Head Unit -Alpine ERA-G320 Sound Field Processor -Alpine CHA-S634 CD Changer -Alpine SPS-171A 6.5, (2 Way Components) -Alpine SPS-690A 6x9 (3 Way) -Alpine SRW-1014D 10” Type R Subs -Alpine MRP-F300 Amplifier (Mids and Highs.) -Alpine M-2000 Amplifier (Subs) -Sound Stream BX-10 (Digital Bass Driver.) -Cadence CAP50F 50 Farad 24 Volt Capacitor with Dual Blue LCD Digital Meter (Amps and Voltage.) -Optima Yellow Top Battery. -STINGER SGP90200 CIRCUIT BREAKER 200 AMP. -Stinger SGP32 PRO 200 AMP Battery Isolator. -DB Bass & Stinger RCA cables. Miscellaneous: -Billet Power Steering Reservoir -Custom Built Power Steering Reservoir Bracket. -Sun Auto Hyper Voltage System GT -ISIS Stainless Steel Braided Power Steering Line. -Hella Horns -Shuriken SK-BT20 Battery (Engine bay) -Optima Billet aluminum Battery Mount. (Battery relocated to trunk.) -125 AMP Nissan Quest Alternator w/ Cody ACE bracket -Remanufactured SR Starter -All NEW Belts -NEW Front Lower Arms -Fuel Pump Relay Mod -Custom Made Intercooler Lower Support Bracket -New Tie Rod Ends -Top Speed s14 aluminum throttle pulley (Blue) Alarm: -Avital Alarm with power lock option. ** Notes: -No AC. -Crack in dash -Needs new windsheild molding. ***Note*** Will take some updated photos when I get the time. Wheels are now gold in color and Silvia brick headlights are now on car. ![]() ![]() ![]() ![]() ![]() ![]() Last edited by JDMbyBlood; 06-12-2021 at 09:19 AM.. |
