s13 brake issues
Hey guys, so ive been replacing all my stock pads and rotors on an 240 s13. I have the fronts done and have now moved onto the back. I have tried to compress the pistons on both calipers with c clamps, with the master cylinder cap off in the engine bay, but even still neither seems to be moving. I cannot fit both break pads into the clips due to lack of room in the caliper. To make matters worse, i had a buddy press the brakes a few times to examine how the piston moved and the left caliper piston started leaking brake fluid after it had extended quite a ways out, and it will not compress back in. Is there a secret to these calipers, Or am I just screwed and need to get new ones? any help is appreciated. Thanks.
