Hey everyone hopefully some one could help me out. I have just swapped my red top sr20det in to my 91 240sx coupe that had a ka24de in it. Car starts up just fine
but seems lile my MAF could be bad cause I cant rev the motor past 2500 rpm s .. seems to run rich to..I have a 62 ecu for the SR fyi.. and It came with a 4 prong connector I believe I heard I may need a 3 prong from like a SOHC .. im not to sure im new the 240 game and yes learning. . Needing some helo from u experts my names zac..91 nissan 240sx stock SR20DET Red top s13 |
Based on the info provided, it definitely sounds like the MAF is bad or is not connected very well. Check the connections to the MAF first. If that does not seem to work, try a friend's SR MAF or a KA SOHC MAF to see if that remedies the problem.
Welcome to Zilvia |
Hey thanks for the tip. Also the connector is bad.. it wont snap in at all its all lose and it slids right out easily. . I if I was to replace it could I buy from a parts store?? The connector thats attached to the harness part.
| 240s, maf, redtop, s13, sr20det |
