1993 Toyota Cresta Tourer V
1jzgte with a built r154 VIN: JZX903042171 Clean title in my name(clean nevada title). Owned for over a year. (Vehicle located in las vegas) $11,000 firm Serious inquiries only. No deals over text, in person only. Please do not text to ask what the lowest I'll go on the price. I will not answer. Willing to deliver vehicle for additional fee. Cash or loan with deposit. (LightStream Loans and J.J. Best Banc & Co. are two different financial institutions that can finance classic jdm vehicles. Both require a higher credit score) Al 725-208-7258 Video of car. Cold start, electronics check. https://youtu.be/i-rVkHrd8ns A compression check video will be added in the next few days. Factory auto, converted to manual. Very good shape. 96,000 MILES. Runs great. R154 build parts list (done in last 500 miles) - New first gear - New second gear - New 1-2 hub - New 1-2 slider - New 3-4 slider - fully built r154 transmission upgrade (driftmotion) - labor done by driftmotion vendor -redline mt90 fluid Other r154 parts used -Beech performance short shifter -Brian crower polyurethane shifter bushing - driftmotion shifter extension service - new shifter housing grommets -Marlin Crawler VSS Vehicle Speed Sensor - reverse light and audible sensor work correctly. Parts used on auto to manual swap - Oem clutch pedal and assembly. - oem aisin Clutch master cylinder from mk4 supra - stage 3 competition clutches 6 puck sprung clutch -Driftmotion R154 Transmission Mount Kit (polyurethane transmission mount) - Stage 3 Competition sprung clutch - Competition clutch lightweight flywheel - stainless steel hydraulic clutch line - 1 piece custom aluminum driveshaft made by Dan's drive line in Las Vegas - OEM rear main seal. - OEM pilot bearing - spare aluminum flywheel will be included Mechanical - New Front rotors and pads - New coil pack connectors - New valve cover gasket - New hood Struts - New serpentine belt -Interior Interior is complete and looks good . New shift knob, shifter and e-brake boot. -Exterior Body is straight no rust. Paint is in good shape. Factory features - Power windows - Power locks - sunroof - climate control - Power driver seat - tilt steering - auto on-off headlights - traction control - power mirrors with 1 button fold in feature. |
| 1jz, chaser, jzx90, lsd, r154 |
