![]() Join Date: May 2005
SR20DET CAS Wiring?
I need to rewire my CAS and only have the S14 FSM. I know:
![]() 1 B - GND 2 B/W - 22/30 3 B - 31/40 4 W - ????? I need to know where #4 is on an E5 [Early S13 Blacktop aka non Type-X/J4] |
![]() Join Date: Feb 2006
Check here: http://www.240sxforums.com/forums/sr...u-pinouts.html
[edit] Just looked through those and it doesn't list them...strange...hope someone who knows chimes in o_O
73 240z Resto project 91 s13 hatch - SR swapped, blown up, parting out |
#3 | |
So that would be 38/47.. Any reason to recant this? |
I'd be careful, because if its an s13, its most likely a different pin-out...that and with them being white, its hard to tell because there are alot of white wires in that connector. When I get home tonight I'll try to meter out mine and figure out what ones go where for you.
Till then, good luck!!
