![]() Join Date: Apr 2004
Origin kit, blinker opinions before dremmeling
well i'm just test fitting the turn signals into the kit and what do you know, no holes in the kit. here's the pics:
Yes it it primered, and no it will not go on without matching paint to the rest of the vehicle. so the options are: 1. dremel a slot into the kit and pray that the light lines up perfectly with the line of the bumper 2. dremel off the tab, and dremel off a fin that is blocking off a place to use a second screw that i could use as a second attatch point. anyone work with Origin stuff before? I heard that the fitment was great, but each piece i have is missing 3/4 of the mounting screw holes according to the FSM that i double checked today. so i'm going to go crazy hanging and drilling the thing anyways..... |
and anyone want to give me a clue how to hang the sideskirts? those have 0 pre drilled holes so i am gong to start with by haveing a blind guy throw a dart at the sideskirt and call that the first attachment location.
but i was thinking that #2 would have the cleanist end results also myself. |
![]() Join Date: May 2002
drill holes and screw in
inside wheel wells areas and under door sill i only did on wheel wells, ziptied on easy removal when iput the car onthe lift |
![]() Join Date: Mar 2002
I hate pre-drilled holes. Like dorifto said drill it in the wheel wells, but drill the skirt first, then offset the one on the car a little so the ziptie pulls the side skirt in more.
PROCEED Grip Gambler |
