![]() Join Date: Jan 2009
Removing S14 sr20 upper intake manifold to replace injectors
Hey all,
I am attempting to remove the upper intake to get the fuel rail off and replace the injectors on my s14 SR20. However, I cannot seem to get the upper intake to come off. I removed the back two brackets that hook up to the valve cover, and the two nuts and two bolts connecting the runners together. I also removed all the hoses, or at least the ones that I don't think will stretch long enough. What am I missing? Are there some hidden secret bolts I can't seem to find? Or is it just really stuck on there and I need to walk it with a hammer to break it lose? Anyone else experiencing this and if so what did you end up doing? Thanks guys. Sent from my iPhone using Tapatalk
RIGHTWHEELDRIVE.com
Middle bolt get ya?
My SR20VET |
Totally, I was sure it was just a bolt to a bracket I had long removed and then just put the bolt in to cover the whole... nope, long ass bolt.
hurp.
RIGHTWHEELDRIVE.com
