ls1 swap kit for s14. will it fit s13?
hey. there is a kit for an ls swap for s14. what can i use out of that kit if anything? any info will help. thankx in advance
91 240sx. sr20det swapped but hoping to do ls1 swap this winter |
![]() Join Date: Jun 2006
All of the mounts will work for a S13 depending on the brand of the swap mounts. The only things that are kinda vehicle specific is the driveshaft and sometimes the headers (also depending on the brand). If you want to trade I got a S13 LS conversion driveshaft that I'll trade for your S14 conversion one. Just a idea. Good luck.
Also the kit I saw has a replacement k member. The sikky one I was looking at uses a fabed oil pan instead. Any thoughts on that?
Either one is good. Of course the sikky oil pan does look kinda baller, but The front sump pan works just as good. I'm rockin the modded cross member and oem front sump pan and I've had no issue. The only thing you might look into is getting a trap door baffle pan (improved racing).
