SR20 Z33 6 speed swap
well ive been a long time Lurker and ive decided to do this swap and document the process i hope it comes out well just keep in mind this will take about a month because im waiting for parts and im also doing some things to the engine.
here is a list of my parts most of which will be here on monday or tuesday -2005 CD009 6-speed with 20kmiles -OEM 350z Slave cylinder -Steel braided clutch line -ACT Extreme 6 puck clutch kit for SR20 -Spec SR20 lightweight flywheel -Shaft Masters Aluminum S14 with z33 tranny drive shaft -Collins Shifter service -Collins adapter plate for SR20 -Collins Crossmember -Dakota Digital converter box heres some pics took the bellhousing off to get it machined 3/8" inspected the gears and they look excellent picked up the bellhousing from the machine shop they did a great job! first parts to come in are here thats pretty much it for now i may put the bellhousing back on the tranny tomorrow but other then that im waiting on parts |
Although this thread is probably in the wrong spot, I'm looking forward to seeing the rest of this as I am also thinking about doing this trans swap next summer. Good luck with the swap!
