#1 | |
TOB and other parts for blitz active single
I have a lightly used Blitz active single I purchased over a year ago. I'm having a hard time finding a definitive answer on what parts to get and where.
What I need is the TOB, sleeve, pressure plate bolts and flywheel bolts. So far through my research I have found that the blitz active single is identical to the ORC super single and a few others but I can't confirm if the TOB, sleeve and other parts are identical. I seem to find different answers everywhere, some people say that the stock TOB and sleeve will work others say the opposite. I did find this post from 2008 reguarding an ORC TOB and sleeve but I'm not 100% sure he is referring to single disk and if he is I'm not 100% sure if the parts will work with my blitz: Quote:
If anyone who has first hand knowledge and can give me a push in the right direction it would be greatly appreciated. |
![]() Join Date: May 2006
sure if you want
18g and 20g turbo users click on me #/f/tech-talk/261219-18g-20g-turbo-users.html
ORC is the manufacture that makes Blitz clutches, super single 409 are the parts that are interchangeable |
![]() Join Date: Jan 2007
ok i know loads about these clutches
you need to measure your standard clutch height bolted against a flywheel, basically how you do it is bolt the clutch asif it was on an engine to the flywheel on a bench, then put a vernier down the centre of it touching the base of the fingers / and bottom of the bench telll me your height there and i will tell you which TOB carrier you need for the bearing its a koyo rct4067l1. I have loads in stock dude they are cheap thanks
#9 | |
Thanks for the replies everyone, I received an instant message from lok that reads;
If someone can provide me with a link to the 409 TOB and sleeve I would appreciate it because after an hour of searching around I can't seem to find any place that sells them. Unfortunately I can't take any measurements yet because I plan swapping the clutch when I swap the engine (current SR20 has low comp) and I don't want to pull it until I have all the parts I need to complete the job and the clutch is just a part of that. |
Bearing only - http://www.rhdjapan.com/orc-release-bearing-a-type.html
Bearing & Sleeve - http://www.rhdjapan.com/orc-release-...aring-set.html Look through RHDJapan next time, their search sucks but you can find it with enough effort. |
![]() Join Date: Mar 2009
RHDJapan typically has everything for these jdm clutches. Except the different depth TOB sleeves, they are just oem parts that are found in a thread here.
#13 | |
#14 | |
Yep, when you are checking out there will be a NOTES section as some point, there you'll want to verify everything you can regarding your parts you need. They will get you the right stuff. Very good people.
